Xmas Break Storage
Started by hawkeye21, December 20, 2004, 05:05:29 PM
Hello,
I am a student and am heading home over break, but am leaving my larrivee. I will be gone for almost a month and I am in minnesota. What kind of precautions should I take as far as humidity? Right now I only have a dampit in the case with the guitar.
hawkeye21,
If the temperature is pretty constant and not too low you should be able to add a homemade humidifier to the case and leave the guitar without worry. I have used a wash cloth soaked pretty well and placed into a zip lock plastic bag. I lay this below the headstock with the case laying flat like you do when you open it. Then I carefully make some slits in the plastic bag allowing the moisture to escape into the case. Rewet you dampit and close the case. Leave the case flat (under the bed works well) while your gone. I've done it a few times before I got a room humidifier. Now, I put the guitars in a closet with the humidifier and refil when necessary.
trailboss,
rollin...rollin...rollin...
Ken,
(It is so not about us...)
2002 Larrivee L-03 Rosewood/Sitka
1998 Larrivee Parlor Mahogany/Sitka (One of first 6 made)
1996 Breedlove Travel Mahogany/Cedar
1992 Taylor 710 Brazilian Rosewood/Red Spruce
1991 Gibson Star Maple/Sitka
1952 Levin Acoustic Mahogany/Red Spruce
Thanks for the suggestion, I'll probably go that route
The 3M sponges work well, also, and have an antimicrobial ingredient which keeps them from smelling nasty
Deb
Larrivee OM-03PA
Larrivee Parlor 01K
Taylor 412e-R
QuoteThe 3M sponges work well, also, and have an antimicrobial ingredient which keeps them from smelling nasty
Deb
Now that's a good idea! :)
#113
2004 Larrivee Parlor BW
2003 Larrivee L-03 BW
2002 Larrivee D-03 BW x 2
