Twelve string question
Started by clark24426, May 08, 2010, 04:24:27 PM
I bought L-09-12 last summer. This is my first 12 string. Not long after I got it, Elderly had a great sale on EXP strings, and I bought several sets of EXP 38's. My problem is changing the high G string. It is only .08 - barely a thread. It seems that in tuning it with a chromatic tuner, I either have the string loose and floppy or it breaks before I get up to the next octave. Am I alone in this? Are there better strings or choices other than lower tunings? Luckily I got two three packs of custom lights from a niece last year for Christmas, and I am robbing the .11's for my high G.
I don't know the gauge your using but at the least it should be a .009 0r .010.Myself I'm using Elixer {I just don't like changing strings}.A set starting with .010 is perfect.This would put your octive G at a .009 and should handle a standard tuning.When I had a Larrivee L09Koa I use a slightly heavier set on it,Dean Markley Vintage Bronze with an .011 in the high "E".The octive "g" was a .010.I know the Elixers are pricey but I do like them better then the EXP.Since I'm playing less 12 string for now,until I find an OM at that point I'll move back to the Dean Markley.You can also try the Ernie Ball Earthwood but they do die a fast death.
My favorite gauge for the L05-12 is 11, 11, 15, 15, 22, 10, 30, 14, 40, 22, 50, 26, I buy them in custom sets from a local dealer but any DR Sunbeam dealer should be able to get them for you. I've blended some others too but really prefer the Sunny's. Curt Managan has a 11-52 set too, but they just don't ring as well on my hog 12.
08 Larrivee L05-12
02 Larrivee DV-09
73 Granada Custom
Kids got the others  :)
Find a shop that sells individuals, and grab a couple extra .08s or .09s and keep 'em in the pocket - thats the one that'll go, so it's nice to have a replacement handy -
Also, check the nut for a straight, smooth slot, and also the saddle for any nicks or roughness. They can cause a bind or a kink that can shorten the life of that string as well.
Quote from: tadol on May 08, 2010, 05:08:12 PM
:+1:
If they are breaking when bringing them up to pitch they are probably catching on something sharp or they are hanging up at the nut and breaking between the nut and the string post. If they are pinched off at the nut it doesn't take much movement of the tuning knob to increase the tension greatly in that short distance, and that small diameter string will just pop.
Also when the string is off, feel the string post for any roughness.
Quote from: clark24426 on May 08, 2010, 04:24:27 PM
If you're breaking it, it's an octave too high.  I agree, at correct pitch it seems too loose.
Clark, I use the same strings on my D03-12.  BUT, I have been for about 2 yrs. getting extra high-G strings in .10 gauge, regular D'Addarrio, as they dont sell EXP's singlely.  I like that little extra that gauge brings to the mix, and the extra strength should settle your issue.   And definitely watch how you wrap it around the post!
Having had a 12 string for 30+ yrs., it is just a fact of physics that that one is going to go--retuning b/c of temp. changes just stresses that little string.
No issue for me now though, as the 12 has been in DADGAD for about 6 months!
I've seen 12 string players that only put one of each of the unwound strings on. But I guess that would make it a 10 string, wouldn't it?
f
Larrivee L-03 w/Gotoh 381 tuners (African Mahogany/Sitka)
Collings OM2Hc (EIR/Sitka)
Schenk Ophirio (Sapele/Cedar)
Bourgeois 00 Custom (Mahogany/It. Spruce)
