I Just Took My Guitar In For Setup
Started by SongMan, October 22, 2003, 08:34:17 PM
HI all,
I just took my Larrivee D-05 to gryphon's in Palo Alto,CA. Frank Ford will be doing the work on my Larrivee. In the basic set-up, I asked him to install Bone. I belive this will make the guitar sound lot better. We'll see how I like my Larrivee after a proper set-up.  :)
You'll love it.A bone saddle is a wonderful idea,and a proper set up to your spec's will really inhance the playing pleasure :P
unclrob, will any luthier know how to use that adjusting tool? I mean, my Larrivee and my Northwood both have them, and I gotta have my Northwood adjusted (B string whines in open position). The guy here that owns the guitar shop only sells lower end (Epi's, that sort of stuff). He worked on a Guild of mine, and a Gibson....he does good work. I'll call him first, anyway....but I want to know: the adjusting of a Larrivee (or Northwood) isn't really "out of the ordinary", is it?
Don't take no wooden nickles, and don't put beans in your ears.
There's really nothing to figure out. Just stick the tool in there, thgere's only one place it can go. You won't hurt anything. Just slide it in there, and you'll see how easy it is.
Anyone can use the tool it's a breeze.
I bought a used D-03 and took it to a local luthier to have set up properly.  I thought it was a nice guitar when I bought it , but it came back a fantastic guitar.
I had a bone saddle put in, and he compensated each string so the intonation is right on, all the way up the neck.  He leveled the frets and adjusted each string at the nut, so I have really low action, with no buzz, no deadened strings, great sustain.
A good setup is worth it,  and I haven't seen a new guitar that comes with one.  My new Taylor is at his shop right now, getting boned, and a fret dressing.  Maybe the hand built guitars come perfect, but I haven't seen a massed produced one yet.
Larrivee D-03
Larrivee D-02 12 String
Blueridge BG-140 (J-45's are overpriced!)
Gibson J-45 (J-45's were overpriced :) )
Let us know how the bone works on the Taylor.  I'm thinking about doing the same for mine.
Mike <><
As soon as my Breedlove gets here, I'm taking my L-09 in for a pro setup. I just played my friends $400 Washburn and that thing plays better than my guitar. Just shows what a professional setup can do.
2003 Breedlove SC20 Coco/Sitka (Nov 26 delivery)
Bone nut and saddle
Schaller nickel tuners
Ebony tuner buttons
L.R. Baggs Dual Element
2003 Larrivée OM-03R: SOLD
2003 Larrivée L-09: SOLD
SO, I got my D-05 back with bone and set-up. SOund is much better. HOwever, I now have buzz on 4th string. errr. I don't know if i want to drive 1 hour to get this fixed. THe shop i went to is an hour away. hmm... Also, I had a hole drilled for K&K pickup. DId all of you follwed exact direction on the manual???? from what i read, I have to sand the saddel plated and clean it with acetone, did you all do this prodedure? also, the manual said, for strumming they reccomend using the tape and NOT super glue direct mount. Do you guys agree that for strummer, use the tape???
I didn't sand but did use acetone...  I also used tape to install the pickups.  Why did you have to have a hole drilled?  Is this an older D-05?  All of the newer guitars have a large enough hole to accomodate the jack.
Mike Jones
______________
K&K Pure Western P/U
Seagull S 12+
Ultrasound Ag30P
ESP EC 100-QM
Webstrings Lights
I belive all D-05's does not come with hole on the bottom. I dont know about the 3's but....  Well how about using the tape? how did you guys like that?
How much does it cost for a bone saddle and a professional setup?
Is it really worth it?
Cooljive every shop charges a different price.
Setups anywhere from $35-$75
Bone saddle from $25-$75
Some of the people here order up after market bone saddle's I think they wer pricing from around $5-$6.
Always check out the person doing your work make sure they garr. it.NEVER leave the shop until you've put your guitar thru some paces and make sure your happy.As you can see some guy's have to traval an hour to get there work done.So please check it before you leave.Always thank the setup person in person,not the guy at the counter.
QuoteI belive all D-05's does not come with hole on the bottom. I dont know about the 3's but....  Well how about using the tape? how did you guys like that?
Surely the D-05 came with a button on the bottom for a guitar strap?  That hole (if the guitar is a late model) according to Michael Larrivee should have been large enough to accomodate the jack.  I just unscrewed the button and popped out the insert and tada it was large enough for my jack...
Mike Jones
______________
Seagull S 12+
Ultrasound Ag30P
ESP EC 100-QM
Webstrings Lights
Actually my D-05 was made in May of 2003. I callled Larrivee and verified. HOwever, I don't think hole on the bottom has all to do with when it was made. anyhow, i am now stressing about installing this K&K in it. The manual isn't as easy as people said.
what is reference pin hole??? I sure don't feel it on my D-05, does that mean it does not have one??? hmm...
Pin hole is short for string pin,the things that hold your strings in the bridge.D05's as far as I know do not come with strap buttons.If your feeling skiddish bring it to a repairperson to install. B)
Thanks for the answer unclrob. I'm gettin' lot of useful info from this forum :)
QuoteD05's as far as I know do not come with strap buttons.
That's what i thought.
If pinhole is for holding your strings in place. what do they as in manual "if your guitar is pre drilled"??? don't all guitar have little hole/slot to hold strings in place?
Also, what is reasonable price for K&K installation???
QuoteIf pinhole is for holding your strings in place. what do they as in manual "if your guitar is pre drilled"??? don't all guitar have little hole/slot to hold strings in place?
My guitar guy was going to charge around $70 for an under saddle install.  Should be about the same price...  The K&K is easy to install though.  So the D-05's don't come with a button on the bottom of the guitar?  Odd...  Most come with a button on the bottom of the guitar which is where the jack comes out...
I looked at the old thread with my questions on the install of the K&K and Michael Larrivee said that the D-03's had the 1/2" hole (button strap) on the bottom.  I guess I was lucky then...  I would definitely take it into a shop for any drilling, but the install itself is easy if you follow the directions.  If you aren't comfortable with it just have it done by the tech.  Good luck...
Mike Jones
______________
Seagull S 12+
Ultrasound Ag30P
ESP EC 100-QM
Webstrings Lights
