Handmade Buzz saw by DR -- need assistance
Started by rockin_ron, May 29, 2007, 11:15:59 PM
Just put some handmade DR RARES PHBs on the git.  These are med/lites (.011 on the E) and now I have a buzz saw.   :mad:  Strings sound OK and they're nice and bendable, but the buzzing while strumming is a problem.  I turned the ole truss rod nut driver a 1/4 CCW.  Did I go the right way?  I had light EJ16s on there before with no problemo.  Suggestions?
Thanks
DR rares run a gage light ie normal lights .12 are medium's on the rares.  medium light Rares are .11 and  medium heavy Rares are .13 i fliped out when i put mediums on and realized they were .12-.54 since they dont stock medium heavies .13-.56 i have to now special order them.  hope this helps.
 :+1:  You have to buy up a size on the DRs or the lighter tension on a low action setup may cause the buzzing...I use the mediums instead of lights now with DRs
Justin
OM-03 MT Custom (Cree Studios "Fish Guitar")
Hope you are being careful with that truss rod. A 1/4 turn is pretty substantial but at least you are loosening it. With higher tension strings you can run a lower action. Cranking CCW puts more relief, (bow), into the neck which might help reduce buzzing. Using the truss rod to adjust action is a bass ackwards way to solve a problem. If you want to run low tension strings you  need to have a setup done that includes checking and changing height at the nut and/or at the saddle to get it right. If you have any high frets you can get buzzing with low action and light strings. Is the buzzing only on chords strummed in first position, on all strings, etc,,?  Players who do a lot of string bending place a pretty high demand on a guitar setup. You might consider taking your guitar to a good technician to get it right.
Quote from: jimmyd on May 30, 2007, 10:51:39 AM
Thanks for the replies.  The guitar was set-up and playing fine with the Daddario's EJ16 lights.  I thought I'd try these DRs because I've read so much about them.  So once I got them on it started buzzing while moderate strumming.  Didn't realize these strings called "med lights" where actually "lighter" gauge than what I took off.  I'll let the neck settle in and see how she plays.  I really don't want to get a set-up every time I decide to try a new brand of strings.  Worst case I'll go back to the EJs or try their "mediums" like someone earlier suggested.
***UPDATE ***
OK here is the deal .... the DRs came off tonight.  After playing them awhile they just didn't sound a full as the EJs.  Best I can describe it is they sounded thin, lost alot of sustain and bass.  Pulled the old EJs out of the garbage (can you believe that, I was that desperate) and put them back on.  Guitar sounds much better.  And the buzz is gone.  I guess this lesson cost me $7.50,  but I don't think those strings would sound good on any acoustic. The gauges are just too thin.  Makes me wonder why they even sell them that light.  Again I didn't look close enough ... I thought when it said medium lights I was getting something similar to the EJ lights.   NOT!
go for the mediums, they play and feel like lights...very nice once you buy a size up.  No need for a setup, just the right gauge string.  good luck! :nana_guitar
A happy ending is always good to read. Glad you are buzz free.  The good news is there are other med/lt bluegrass, which is a med/lt mixed set and lots of other other strings to try besides DR's if you get a hankering and it is a completly reversible experiment. I've only tried DR's once and didn't like em much either.
