Please Explain What A PreAmp Does...
Started by Cybenator, November 11, 2006, 08:44:39 AM
Ok, here is the deal. I just purchased a mint used UltraSound AG-30. I have 2 Larrivees with differnet types of pickups.
First is the OM-03 Koa with a passive Fishman UST
Second is my OM-03 Walnut with Baggs active iBeam
I have NO experience with playing any type of acoustic through an amp and  I would like to have someone explain the "PreAmp" principles to me if possible....
Are there certain manufactures and or features I need to be looking at.
Greg
Larrivée L-05 Red Spruce Top
DeArmond M-68 Moon Blue
Fender Bullet S-2 Sunburst
Fender Telecaster Thinline
Peavey Predator
A preamp basically boosts the signal from the guitar into the PA/recording desk/whatever you're plugging into.  Most units also offer some kind of sound-shaping in the form of a three-band EQ.
I use a K&K Pure Preamp a fair bit and it is immensely preferable to relying on a wound-up gain control on the PA.  Depending upon your requirements, I would recommend investigating those along with any others you are considering.
Apologies if this answer is too literal!
"Looks like satin, feels like silk!"
Larrivee D-03
Larrivee J-03R
Larrivee D-03E Mahogany Top
Larrivee L-03 12 Mahogany Top
Larrivee OMV-03RE (sold to friend whose style just suited it better!)
Acoustic sounds (such as voices or a musical instruments) are often recorded with transducers (microphones and pickups) that produce weak electrical signals. These signals must be amplified to line level where they are more easily manipulated by other devices (such as mixing consoles and tape recorders). Such amplification is performed by a device known as a pre amplifier (commonly known as a "preamp"). After manipulation at line level, signals are then typically sent to a device known as a power amplifier, where they are amplified to levels that can drive headphones or loudspeakers, which convert the signals back into sounds that can be heard through the air.
Line level is a term used to denote the strength of an audio signal used to transmit analog sound information between audio components such as CD and DVD players, TVs, amplifiers, and mixing consoles. Depending on the application, line levels are stated in units of either decibel volts (dBV) or decibel volts unloaded (dBu). Consumer audio equipment line levels are rated in dBV, and the most commonly used reference level for such equipment is −10 dBV, which corresponds to a signal of about 0.3162 volts RMS. Professional audio equipment line levels are rated in dBu, and the most commonly used reference level for such equipment is +4 dBu, which corresponds to a signal of about 1.228 volts RMS.
Courtesy of Wikipedia.com
2016 Martin 000-28vs 12 fret
2014 Taylor 814ce
2014 Godin Multiac Classical
2012 Gibson "The Golden Age 1930's" SJ200
2012 Squier Vintage Modified 70's Jazz Bass
2010 Gretsch Electromatic G5122DC
2009 Taylor GA3-12e
2004 Fender American Deluxe Stratocaster
1981 Rickenbacker 320JG
1968 Yamaha FG150 Red La
Quote from: Cybenator on November 11, 2006, 08:44:39 AM
You already have two preamps.  One is in the Ultrasound AG30.  The other accompanies you active iBeam.  Keep yur cable short between the koa guiar and your amp and it should work.  You will notice a volume diference between the two guiars plugged in.
+1 to what sdelray says.  The guitar with the iBeam will be louder.  You'll just need to turn the volume up more for the other guitar.  Also, remember to turn the volume all the way down when switching guitars.  If you don't, your audience will hear a loud unpleasnt POPing sound.
Have fun!
David
www.davidberchtold.com
I shall bring my question here since nobody answered in the Larrivee guitars section of the forum. I also have a question about preamps and maybe this well help Cybenator. I just got my D-50 equipped with a martin thinline. It sounds good through the system at church played without a preamp and I even used a wireless unit today. My question is if I get a LR Baggs PARA DI will it make alot of difference in the tone shaping of the instrument. Is it worth the 160 dollars that I will spend on it?
Thanks
Dan
Dan
I have found when gigging and plugged-in, I prefer using a pre-amp or an EQ pedal where I can control my sound jsut a bit and not be so dependent on the sound guy (if there is one).
I can also easily balance the guitar and voice without a trip to the sound board or amp. I have one a Dean Markley belt loop pre-amp that works on the passive pickups.
My guitars with on board pre-amps give me the control I want. If I am strumming I need to lower the guitar level as opposed to a finger picked song.
It is my belief that "the sound" we are looking for varies significantly from player to player. In my experience many sound guys like it too loud.
My opinion is keep as much control as possible, the audience will remember and judge you, not the sound guys.
SD-60 SBT
O-50 TSB
OM-03 Koa
D-09 12 string
Gibson-J50
Gibson Blues King
A gaggle of ukes
When you make a signal "larger" you can't simply just plug it in.  You ever try to turn up a really cheap clock radio and the speak sounds like it's gonna crack from the distortions, but there is no bass?  That's due to a weak signal.  This is almost analogous to strumming a guitar too hard.  At certain points, the guitar just doesn't get louder, it gets distorted because the maximum output has been reached, and any energy input beyond that is doing somethign else (ie, not making tones)
The preamp amplifies your signal such that it's strong enough to be accepted by other devices properly.
Larrivee LSV-05
Larrivee LV-09FM
Larrivee CS-30
Yamaha Chronos LL-16
Yamaha Pacifica 112J
Martin LX-1
Fender American Stratocaster Delux
Fender Mexican Stratocaster
Fender Mexican Telecaster
Rivera Sedon
I've learned a lot from following this thread.  A related question:  Most pickups (or many) have built-in preamps.  As do many amplifiers or PA heads.  So...what about things like the BBE acoustimaxx, or Mama Bear, or other tone shaping boxes and gadgets.  Wouldn't that mean plugging a preamp into a preamp into a preamp?  Can someone provide some advice on this?  What does this do to ones signal?  If you have an active pickup, and want greater tone-shaping capability, can one go into another preamp or DI box of some sort and then into a amplifier or PA (I do this, but am unclear as to how this affects signal).
Thanks!  I've much to learn about sound reinforcement!!
Brent (Madison, WI)
Gain Control is present on them.
Larrivee LSV-05
Larrivee LV-09FM
Larrivee CS-30
Martin LX-1
Rivera Sedon
Pre-amps and DIs also boost the over- and under tones that are essential to the acoustic tone out of the speaker. Keep your guitar cable under 8' to avoid drop-off.
For most non-magnetic acoustic guitar pickups, the most important job is lowering the output impedance, or "buffering" the signal. Typical pickups may have output impedance on the order of 100K~10 MegaOhms. Even the "high impedance" input on most PA equipment is only going to be on the order of 10K to maybe 100K. That is in fact high compared to the "low impedance" inputs, which are typically 300~600 ohms. If you use a high impedance pickup with a long cable, you will also get a lot of loss in the cable even if you are using an "acoustic" amp with a suitable input in the 10M range.
It isn't always desirable to actually boost the signal in addition to buffering it, but sometimes a moderate boost can reduce noise. Think of the cable as an antenna for noise. If the signal is weak and requires a lot of gain at the PA, then turning up the amp increases the signal AND noise. If you boost the level of the signal at the source, before most of the noise is injected, then less gain is needed downstream so the noise isn't amplified as much.
In case you are wondering why all amps don't have an input impedance in the 10M range, the answer is (partly) noise. In a high impedance system, it doesn't take much energy to produce a high signal amplitude. So, even a weak field from a distant flourescent light or computer or whatever can produce a nice clear signal in your PA. With a low impedance system, it takes a lot more energy (a much stronger field) to produce the same level of noise. Basically, the lower impedance "loads down" the noise just like it loads down the signal from the pickup.
