different saddles
Started by guitarforlife, August 11, 2005, 05:23:45 PM
i've heard many testimonies of enhanced sound when changing a saddle to bone , fwi, or elehpant ivory. has anyone done this and not noticed any improvement? basically sound staying the same or possibly getting worse from messing with the original set-up. just curious to hear if there's another side
I put bone in My Seagull recently.  Hell of an improvement.  I probably wouldn't bother with ivory ... it's not as dense as bone (bone carries weight) and density is the point.  So I can't give you the "other side".
I did have to reevaluate my string choice ... I was using 80/20s to bring out qualities in the guitar that don't need to be brought out anymore.  Like bass 'slam' and string separation.  I suspect this is common.  Also, if the bottom of the saddle isn't flat, it isn't going to sound right no matter what the material.  The fit is probably about as important as the material.   Since plastic saddles come molded all the same 1/8" or 3/32" thickness (which is why almost all factories use them) and you can't fit them as accurately to the sides of the slot, you can get a much better fit with a bone saddle, which should be a bit oversized.
It's just about impossible to eyeball the saddle bottom accurately, even with a straightedge (the only problem I had with my Colosi saddle was thjat he says to do this in the instructions ... I feel they're biased a little too far in the ease of use direction) .  You need to use a jig or get a blank with the bottom already flat and adjust the top.  All the negative effects I've ever heard about from bone saddles sounded exactly to me like the bottom wasn't flat ... you'd get the same detrimental effect with a plastic one.  I have, and now I know that you need to use some kind of jig to lower one if you haven't been a luthier for years.
I researched this a lot on the web before I did it by looking at luthier's forums.  These people know what they're talking about, they're largely talking to each other (ie no BS), and frankly you can't necessarily trust the objectivity of someone who's just spent a lot of money on something and wants it to be the best.  This is particularly true of expensive bridge pins, which make no sense to me at all.
I couldn't find any dissenting opinions amno0ng the pros.  Bone is the best material.
Interesting discussion that hopefully I can add to in a few weeks.  I purchased an ivory saddle from Bob Collosi based upon my desire to add some warmth to my LO3R.  I decided to let my local luthier do the installation since I needed a setup anyway.  Since I am travelling for the next two weeks I drop off the guitar and saddle tomorrow and am anxious to see what improvements or changes really happen.
Pat Mc
Hoser Rob, I ordered me a Colosi saddle this pm. I'm really looking forward to see how my S6+ sounds with the bone saddle, if it sounds as good as I think its going to i'll go ahead and retrofit the other four birds I have.
I'm thinking about doing a A/B with my D-03, it came with a tusq saddle installed but Rob was kind enough to send me a bone saddle in the case so next time I change strings i'm going to drop the bone in.
Ruben
I put a Colosi bone saddle in my L05MH and heard no discernable difference.  I was very careful when shaping it, the bottom is perfectly flat, and I got a very nice fit.  I did leave the saddle a little higher than the factory tusq saddle.  I actually put the tusq saddle back in the Larrivee.  It was definitely not a change for the worse, but I did not think it improved the tone.  However, I should stress that I thought the tusq already sounded really good.
I've put a bunch of Colosi bone saddles in.  It made an incredible difference in my Avalon.  It eliminated some pesky buzzes (probably due to notches in the TUSQ saddle) and really brought out the sustain in the guitar, which was good to begin with.  In every case, there has been an improvement in sustain with a bone (over TUSQ), moreso in some guitars than in others.
Bing
Larrivee J-09FM
Taylor 814ce
Music Man Axis SS w/piezo
TUSQ and micarta are not "plastic."
I like the tusq...and for under saddle stuff (for pick up).....very consistent. They say it's man made ivory. Works for me.
Don't take no wooden nickles, and don't put beans in your ears.
I put a bone saddle in my D60 and I had a hard time telling the difference from the tusk saddle that was in it. Now I have a black graphite saddle in. I am very satisfied with this saddle in terms of sustain and tone and note seperation. just my 2 cents
Larrivee D60
Taylor 422 Maple
Delux Tele Plus
I put bone in my parlor.  I felt it made a slight difference.  I often tune to harmonics and felt they rang out noticeably clearer and louder then with the tusq.
-josh
Larrivee P-03MT
Martin 00
Epiphone Bluesmaster
The boning of the saddle does help.  i've also used the ivory and that makes a difference.
Sometimes the improvement is not for the better.  Some guitars sound best with the original tusq.  I've had to change back a few times.  One thing that does improve sound right away is switching to eboney pins (around 12.00) a set.  You do have to sand them to fit properly though.
Also don't forget the nut material.  Bone makes a great nut and works very well for DADGAD players like me.
Peter
creestudios.com
Art Guitars and more
re: density is it. .. if density was it, people would make bridges out of lead metal.
Its the ability to transmit vibrations from the strings to the bridge. In my mind, the transfer of vibration should happen with minimum distortion of the waves. However, I do believe certain materials transmit certain frequency ranges better than others and will color the resultant sound in differing ways. Sort of like playing with your notch filter on an amp.
So what exactly is TUSQ the man made material composed of?
I just boned my martin.  Did I just say that outloud?
Breedlove SD-25 Custom
1973  Martin Sigma DM-5
