Relative Humidity Level?
Started by Fergy07, February 16, 2005, 08:09:19 AM
What is a good relative humidity level range (or is that all relative?)? The room I keep my guitars in, tends to stay between 55-60 degrees and 35-40% humidity (using the remote Radio Shack Hydrometer sensors). Is that within acceptable limits? I'm sure this info has been requested before, but there are so many threads on the topic, its hard to find the info.
Thanks,
Andy
Larrivee OM9
Larrivee PO-09 Koa
Breedlove SN20
Webber 000 Cedar/Maple
According to the Larrivee pamphlet that comes with their guitars...
"Your Larrivee Guitar was built at a strictly controlled relative humidity, that is from 37% to 42%, relative to 24 degrees Celsius (75F). When the relative humidity exceeds 60% the guitar will begin to expand... The villian in winter is excessively low relative humidity, i.e. lower than 40% relative to 24C or 75F. Exposure to any rate lower than 40% for any period of time will most surely result in damage."
I keep my guitar room humidified with a warm air humidifier set to 50%. When set to 50% the room varies from 45% to 55% RH.
2016 Martin 000-28vs 12 fret
2014 Taylor 814ce
2014 Godin Multiac Classical
2012 Gibson "The Golden Age 1930's" SJ200
2012 Squier Vintage Modified 70's Jazz Bass
2010 Gretsch Electromatic G5122DC
2009 Taylor GA3-12e
2004 Fender American Deluxe Stratocaster
1981 Rickenbacker 320JG
1968 Yamaha FG150 Red La
Andy,
I used to know all this stuff, but with increasing age, my mind is deteriorating.  If the ideal climate for you guitar (according to Larrivée) is 70 degrees F and 40% humidity, I am a little concerned that the numbers you gave might mean your room is too dry.  Your humidity range of 35-40% seems OK, but the temps are cooler than recommended.  I think this may mean the relative humidity in your room is a little lower than it should be.  Cool air holds less moisture.  I may be way off base here. :huh:
Jerry  #698
2001 Larrivee D-09
2001 Seagull M-6
1992 Alvarez 5040
c. 1995 Yamaha CG-150CA
1998 A&L Ami
QuoteAndy,
I think you're correct. Andy's on the too dry side.
Coming from viewpoint of the dry climate of Santa Fe and the Rockies, 35% is actually acceptable.   I see very few problems at that level.
Of course, I keep all the guitars out of the cases and on stands to humidify the entire guitar.  Also at 35% or lower, is when the humidifiers get turned on.  I've come to think 40% is ideal.  In  summer, I can get them to 50%.
I also watch/inspect them constantly.
Now if I buy a humidifier, I assume I would buy one which automatically detects the humidity and turns itself on and off, correct? But, wouldn't being in the case be a detriment in that case as the humidity would most likely be mostly prevented from entering I would think.
Andy
Larrivee OM9
Larrivee PO-09 Koa
Breedlove SN20
Actually Andy, quite the opposite.  The case helps maintain a steady level of humidity.   I keep my room between 40 and 50% humidity level with a room humidifier but the humidity inside the case remains constant at 45% - 46%.  It is my belief that the wood (or whatever a case is made of these days) actually hold the humidity and helps keep it humdified.  Just my theory....
NewStrings
Lord of the STRINGS * Kronbauer TDK *  Taylor 614ce  *  Larrivee LV-03RE  *  Taylor 810ce  *  Martin D-18 Custom  *  Gibson ES - Les Paul  *  Gibson J-45  *  Fender Telecaster  *  Jason Romero banjo  *   National Estralita Resonator * Muth mandolin
QuoteAndy,
Perhaps it isn't deteriorating. It may just be drying out. :P
Sorry, I couldn't stop myself...
I'm no expert, but I think most manufacturer's agree, RH of 45 to 50 degrees is ideal.  There is an excellent commentary on the Santa Cruz website from Richard Hoover, about "caring & feeding" that tells how variances outside these parameters result in damage to the guitar:
http://www.santacruzguitar.com/care/index.html
Our climate is not so severe in Tennessee that you can't control a single room with a small 4 gallon humidifier, and maintain this ideal range.  But when the humidity fluctuates outside (rain) you can see the readings change indoors within 12 hours.  The problem is, how to regulate it when it gets over 50%...  You might need to run the A/C (in the winter?) to get the humidity under control (unless you have a de-humidifier). ;)
It really depends on the conditions where the guitar is made and I thin Larrivee reports their warehouse is 40% or maybe 44%.
It also depends on where you live.  As peter said... it is different when you live in a very dry climate.  I live in Colorado so I do my best to keep my guitar right at 40%.  If it falls to 35% I don't worry but below this might be a problem.
I actually like my guitar a little on the dry side.  I think it sounds much better and it is less of a shock when I take it out of the house.  When I have had my humidity up around 50% or more it started sounding a little dull and muffled.
Thats my story and I'm stickin to it.
-josh
Larrivee P-03MT
Martin 00
Epiphone Bluesmaster
Don't worry, it's all relative....  ;)
QuoteActually Andy, quite the opposite.  The case helps maintain a steady level of humidity.   I keep my room between 40 and 50% humidity level with a room humidifier but the humidity inside the case remains constant at 45% - 46%.  It is my belief that the wood (or whatever a case is made of these days) actually hold the humidity and helps keep it humdified.  Just my theory....
NewStrings
It makes sense that if you keep the guitar and case in a humidified room that the case could be kind of a buffer on humidity swings. I think I saw somewhere that Collings puts their cases in a humidified room for several days before shipping instruments.
Thanks everyone for the replies, now I have too much to think about. I live in NJ, where it tends to be humid in the summer, and mixed in the winter. We have central AC, and baseboard heating. The room is my utility room, which although it doesn't have either the heat or the air going directly into it, is an enclosed inside room with no windows, and tends to remain a fairly constant temperture, the humidity I am trying to track over time. Sounds like a nice project to begin plotting in Excel and make some effective graphs and then some slides to justify the expense to my wife.
Any recommendations on a humidifier?
Andy
Larrivee OM9
Larrivee PO-09 Koa
Breedlove SN20
Yup the rockies are completely different and the advice is also.
I just use the fairly inexpensine humidifier from the drugstore.    I use the non -heat/ultrasonic  type with distilled water.
Watching and listening to the guitars is more helpful to me but I also have two hygrometers.
It gets to 8% outdoors in the winter.............or less.
I check the action, bridge area, and frets daily.
One question....and i've beaten myself to death trying to figger out this humidity stuff!!...if Larrivee builds it's guitars in in a controlled environment of 37% to 42% humidity relative to 24 degrees C (75 F), then why is everyone talking about the ideal humidity level being at 50%, or 45%, or 40 to 50%...to me it would seem that the ideal level would be 37% to 42%, if that's the environment the guitars were built in..but apparently i am incorrect...i just need to know why...also, 37% to 42% RH at 75 degrees....how would that transpose at a temperature of 70 degree...one of these days i swear i'm gonna get this humidity crap right!!!
I agree, and I'm glad one of us will, as it is not going to be me.
Andy
Larrivee OM9
Larrivee PO-09 Koa
Breedlove SN20
