Gloss Finish On The Neck An L-05
Started by mcozma, January 03, 2005, 06:36:22 PM
Today, I tested an LV-05E that had gloss finish on the neck. The guitar sounded great, but the neck was not very smooth because of the gloss. Anyone else had a similar experience? As far as I know, Larrivee doesn't gloss their guitars' neck; anyway, it was the first guitar with this 'problem'.
OM-03R
i have a gloss finish neck on my lv-04.  i love it, but i guess it's a personal preference thing.  i've always preferred gloss necks to satin.  i had a satin neck on my taylor and it went back to the shop really fast.  couldn't get used to it.
i have no idea if gloss is common on larry's, though...
.pete.
FOR SALE - 2000 Larrivee LV-04
1999 Gretsch Historic Hawaiian
On the -05 series and above the necks used to be gloss. In 2003 Larrivee started a change over to satin necks on all models. There was a period of time when both were coming out of the factory. If I recall correctly.
...what Randy R said.
my L-09 has a gloss finish neck. it doesn't bother me a bit, but i can see where somebody might prefer one finish over the other. i think satin finish necks may be a bit smoother.
i have picked up a gloss finished guitar, where the neck was not smooth, but i think the finish wasn't polished or buffed properly,,,don't think the gloss was the problem though.
I too have Gloss neck on my L-05 and doesn't bother me a bit.
If you're used to satin necks, which is the rule in most production guitars now, then going over to gloss can feel a little 'sticky.'  That said, I prefer a gloss neck.
E. Shoaf
I have used 0000 steel wool and a lot of elbow grease to remove the gloss on a few of my guitars, as suggested by Dana Bourgeois. If you go slow you can buff to the point that is perfect for you.
Well, as most of us "old timers" know, a satin neck wasn't even an option.  My L-05 is gloss, my Gibsons and Guild are gloss.  My Taylors are satin.  And really it makes no difference.  I'll tell you one thing though, my satin necks are pretty much gloss now.  If you play them enough, the oil from your skin along with friction turns satin to gloss.
Johnson L Body
A&L AMI
Cort Earth 900
Taylor Big Baby
Gold Tone PBR
Regal RC-51
Fender R48
Ariana Classical
Seagull Artist Grand
Gibson SJ
Gibson J-55
Taylor 355
Taylor 414
Larrivée L-05
Guild D-55
Taylor 614ce
Taylor 714ce
Taylor 814c
Kent archtop
Silvertone archtop
Les Paul Custom
Johnson L Body
A&L AMI
Cort Earth 900
Taylor Big Baby
Gold Tone PBR
Regal RC-51
Fender R48
Ariana Classical
Gibson SJ
Gibson J-55
Taylor 355
Taylor 414
Larrivée L-05
Guild D-55
Taylor 614ce
Taylor 714ce
Taylor 814c
Kent archtop
Silvertone archtop
Les Paul Custom
I like the satin much better that the gloss.  The gloss is OK in the winter, but when it's warm, my hands stick on the gloss necks.
I've de-glossed a couple of necks using steel wool on one and the MicroMesh finishing cloths. I strongly recommend the MicroMesh. With these, you can take the gloss off, and leave the finish shiny and without scratches.
CM
can you tell us a bit about how you used the MicroMesh. What grit did you use and so on. Thanks!!!!!
2011 Larrivee D-03R JCL
2010 Fender American Stratocaster
2010 Carvin C-250
1997 Fender MIM Telecaster
I have both satin and gloss neck guitars. The satin necks feel faster. I feel I can move easier. The gloss neck (like said before) feels a little sticky. Like anything it's what each person prefers.
jc
jc
