What makes Larrivee tuners "mini"?
Started by musical123, February 26, 2025, 11:16:58 PM
0 Members and 0 Guests are viewing this topic.
Hi,
What makes Larrivee tuners "mini"?  Is it the short shaft that the strings wrap around? I can only get a little more than 1.5 wraps on the low E string (get 2-3 wraps on other acoustics), so I assume this is what makes them mini? If so, is it due to headstock angle?
Thanks
I've only seen them on the smaller headstock of the parlor model, and maybe the T-40.  I believe it's the size of the gearbox and the knob you turn.  The shaft should be standard and not affect the amount of wraps. Other wiser members may know more than me, however.
Larrivee Forum VII
Larrivée OM-03R maple leaf inlay
Thanks for the reply.
My late 90s D-03 definitely has a shorter shaft compared to my Taylor and Martin. I'm assuming that the headstock angle is not as steep on the Larrivee that necessitates the shorter shaft, but could be wrong. I'll try to post pictures later.
