end pin size
Started by Ticl, February 13, 2025, 10:26:54 AM
0 Members and 0 Guests are viewing this topic.
I have a 2024 simple 6 om. am i correct that the endpin hole is 1/2 in on Larrivees? want to add a pickup and hoping not having to enlarge hole. thanks
i went ahead and sent email to larrivee. endpin hole is 1/2. set up for 1/2 in jack.
I have found Larrivee CS to be particularly responsive. I usually get a response the same day if not within a hour or two. I have a similar situation with the Larrivee I just got - the previous owner had a pick-up installed and prior to trading it in, took the pick up out leaving behind no jack or end pin . . . Just the hole where the end pin should go. Larrivee CS hooked me up with the right end pin. I hope that you have similar good luck.
Slainte
2023 Martin D28
2022 Furch D-SM
2004 Larrivee DV-05
I forget offhand what year they changed, somewhere around 2008 comes to mind but that may be a wild guess.  But at some time it was changed so all the end pins were drilled out to 1/2" (or 15/32 maybe).  One of those easier to just drill them all than to go back and drill the ones that get pickups.
Ed
Had very good responses from Larrivee when I wanted a replacement end pin,after I removed a pickup from a 000-60 I had a while back,replacement end pin blocker arrived in no time.
