caged system?
Started by DaveyO, November 05, 2007, 11:26:25 PM
0 Members and 0 Guests are viewing this topic.
Ok , I have been strumming my favorite songs and writing a little bit for a lot of years now but its time to learn more .I have heard of the Caged system ,if I spelled that right.
I just want to be able to solo a bit and learn more of how to build chords and whatever else that will make me a better player and jammer.
the music I like is mostly poppy stuff, James Taylor, John Mayer, America,Jason Mraz
No bluegrass or Tapping or tricks,just how to get around the guitar better,
Has anyone used the Caged system? Or is there another way to go?
thanks,Dave
Maybe I don't understand something but CAGED seems to be a word thrown around to me and used to mean different things, some which don't make sense to me. For example, many start by saying the CAGED chords are ones you can use to play any song, in any key, by simply moving them up the neck to get "higher" chord. Then they have open G as one of them.  Better take you're fingers to Yogo class for that.
My suggestion is if you want to learn more about chords, then take the time and do it.  Learn what # notes of the scale make up chords. ie major 1 -3- 5   minor 1- flat 3-5  dom 7     1-3-5 flat 7 ect.
Learn all the open chords and understand how they're made. See that E A and D are really the same chord shape. You're just moving the whole chord chord down a string and then making up for the B string which is down a half step relative to the others. (so when going from g string to b string you have to raise that note a fret to stay relative.) Once you understand them, you can take the chords that are EASILY moved up the neck and find chords up there. When you go up it will behoove you to make minor changes in how you make them so they'll be easier to make or leave a finger available for hammer on ect. If you understand how they are made, you can do this. If you don't, you're just huntin and peckin.
Take all the chords you know and see what notes you can add to them for flavor. Find bass runs to tie chords together. Trebles runs that can lead to next chord..
  Basically learn all you can about chords and just play around with them to see what you can add while in chord shape. Learn about different standard chord progressions by number systems and learn them in different keys. Other than that, practice the rest of your life! Bottom line is, unless I don't understand or haven't heard a good explantion of CAGED, it just seems to be very basic explantion of chords or way to learn chords that's limited.
The CAGED system is mainly about scales.
Here's the major pentatonics:
Notice the C and G shapes? They look like open postion chords. However thats not important, IMO. What is important is that you learn 5 different scale patterns that of course can be used to play Major and minor scales and the rest of the modes. By removing certain notes you get the pentatonics but it's easy because you don't have to relearn any patterns. Then if you know your music theory you can build chords from the scales. Like if you're in C major and want to play the II chord you start on the 2nd note of the scale then stack 3rds: C D E F G A B C . After you know the C major scale in 5 different patterns that cover the fretboard it's easy to find that II chord wherever you need it. It's a great way to learn the fretboard and if you apply yourself music theory too.
I decided to try to learn how to read music a few months ago and stumbled across
Bruce Emery and his "Skeptical Guitar Vol. 1- The Big Picture"
He explains CAGED (CGDAE is harder to say) in a way that I could relate to.
http://www.skepticalguitarist.com/
I am studying his fingerstyle book now.
Larry
<1 or 2 nice ones>
Thanks for the info  gents.
Got to get to work now.
Dave
I like what Jeremy pointed out. To be clear, you can take those 5 patterns and stack them on top of each other to cover entire fretboard for 1 key. Like take the G shape (what looks like 1st fret would be the nut,open) then stack the E shape on top of it. The bottom three notes of the E shape lay on top of the three notes on 3rd fret of G shape, in other words the top of one shape is the bottom of the next one moving left to right. So you can overlay them right up the neck and that would be all the penatonics for 1 key. Once you get that whole shape memorized, you just slide the whole thing up or down depending what key your in. Make ya a blank fret board and fill in the dots on up to the 12th or 13th fret.
I used to do that and then circle chord shapes out of the patterns. Those are pentatonics though so know that theres only 5 notes out of the scale there. Basically anywhere theres a 2 fret space, another note could go in there to complete major scale.
follow flatlanders opeining advice. You wind up learning the fretboard. You will get to see how scale tones fit inside of chords, and in turn how the melody works against the chord structure. CAGED like myraid of other systems, offer short cuts to being able to play tunes, or more correctly in terms of CAGED, of how to easily transpose tunes. In depth strud of the fret board, will open up all of the worlds of music available through the guitar. More tedius WORK at the start, no question. But a much bigger payoff at the end of the day.
