Technique good for the guitar?
Started by Jeff, August 29, 2007, 12:27:52 AM
0 Members and 0 Guests are viewing this topic.
Recently, on another forum, there was some discussion about pressing and then releasing pressure on the lower bout to get a vibrato effect.  There was some controversy over whether a change in pitch even resulted.  The person who suggested it got some flak about it all being in his head.   I'm not sure why it was disputed.  I tied it, and It works.  You can hear it plain as day.  Hit a big fat chord, press with your right  elbow on the lower bout (no offense to lefties), and up goes the pitch.
Is this okay?  It seems like an unplanned-for stress on the guitar's structure that might stress it in ways unplanned for by the builder.  But it sounds cool. I had never heard of this before.  Add to your technique or avoid it as damaging to your guitar? I lean towards the latter.
Jeff
OMV-40
OM-3R
LV-03
Martin OMC-15E
Late 70's Univox Acoustic
Kentucky Mandolin
It's probably fine for the guitar. It would be the same thing as tuning the guitar a few hz sharp; unless you really press on it.
Sure it works. You may be pulling the neck back as well. Let it be a lesson about how you affect sound by placement of you hand or especially arm/elbow. I (subconciously at this point) for instance at times make sure my arm is not touching front of guitar ar all when I want something, usually a fat open chord, to ring out. When you rest arm across front of guitar, it gets muted.
I just happened to stumble across this thread, and I'm sure glad I did.  I was completely unaware, and never paid any mind, that contact of my arm, to the lower bout, could in fact, be muffling my intended sound.  Now that I think about it, it does make perfect, and logical sense.  I thank you, folks, for inadvertently, pointing out something I do, that I was completely unaware of, for muffling my tones, is NOT my intent.
Thanks!
Sharon
Larrivee OM-09
~~Music is all about a movement - and if it creates movement, in at least two people, one being other than yourself, then it was all worthwhile, to have given it life...S.E.H 05|12|2007~~
