Author Topic: posting pics  (Read 420 times)
DaveyO
« on: August 25, 2017, 05:07:24 PM »
Is the only way to post pics is thru flkr?
I want t show off my pain Jane beautyd02
Dave
broKen
« Reply #1 on: August 25, 2017, 05:36:06 PM »
Dave
Hey Dave, pain is a good thing, but if you can reduce the bites below 2000, you can add them straight from your device.
A Hebrew, under the Spell
Pain is a good thing
The cost of living is...life
JOYCEfromNS
« Reply #2 on: August 25, 2017, 06:05:19 PM »
Assuming you are using Windows:
From where I saved the picture I know I have to resize it to post on the Forum thus I use a program that comes with all Windows called Paint:
Right click on the Picture and highlight Open With  -  the options presented choose Paint
From the Menu Bar Choose Image
From Images dropdown click on Resize
There is a Horozontal and Vertical Boxes I put 25 in place of each 100 that is in these boxes  ( this reduces the size to 25% of the original) I then save this to another location on my computer where I can add it to the Forum
Play around with it you won't break anything. Once you are able to resize your pics you then go into the additional options below the text box of each post and upload your reduced size photo.
tuffythepug
Global Moderator
« Reply #3 on: August 25, 2017, 06:59:03 PM »
Well, Flickr allows you to post pictures in a larger size and higher definition.  But Andrew"s method works too
DaveyO
« Reply #4 on: August 29, 2017, 07:14:26 PM »
Let us see if this works
Not my guitar,but same
tuffythepug
Global Moderator
« Reply #5 on: August 29, 2017, 11:21:52 PM »
Looks like you got it.
