String reccomendations for Open D/slide
Started by pcmancini, October 10, 2005, 11:03:50 AM
Hello all,  I am using my OMV-03 to play slide in Open D.  Do you all have any string reccomendations for a nice FAT blues slide sound.  I am currently using John Pearce Slack Key strings (which are a variation on PB mediums) as follows - 56-45-32-24-17-13.  Am looking to try some others as well.
Thanks,
Paul
OMV-03
Rhodes Mark 1
Usually for slide playing you need to make a compromise on raising the tension of the string or raising the string from the frets to keep from buzzing.   Some people advocate a small shim under the nut, about the width of a credit card, while others try bowing the neck a bit.  String tension would be the best place to start, since the instrument is not changed.  You want heavy strings, for example on my National the guages are 16 - 19- 26- 36-46- 59.  Try these one at a time and decide which is best for how you want to play slide.
You may even like a bit of a heavier string for open D but doubt you would need other changes.
Bill
You've got the right idea with the gauge pattern you're using with the Pearses but a .015 1st string would help fofr starters.  You can certainly experiment with heavier strings but I wouldn't put heavier than medium tension on it unless you're talking about just the 1st string, where you'll spend a lot of time anyway.  Larrys are rated for medium strings and I wouldn't use National gauges on it.
If you want to use alternate tunings go immediately to the faq/support section at www.daddariostrings.com and print out their string tension guide ...  it's invaluable.  That way you can use a medium 3, 4, and 5 and increase the ones downtuned a whole step.
What you're probably looking at is a combination of mediums and heavies, but I would not try this unless you plan to leave it in open D.  There are very few guitars I'd use more than medium tension on and  Larrys are all rated for mediums.
Also, unfortunately, you aren't likely to get as fat a sound in open D than in open G with most acoustics.  The fundamental body resonance of most of them is around F# to G# and G usually just works better with the natural resonance of the guitar.  That's why it's the most popular acoustic guitar open tuning.  Exceptions do occur though ... you just have to try both.
I found playing slide I prefer open D too ... I just like that key and having the root in the bass makes more sense if you don't do a lot of root-5th bass stuff.  Like most, though, G sounded so much better on mine that's what I ended up using instead.  In fact I find G tuning can make you a bit lazy because you can easily lapse into doing simple patterns because it just sounds so good.
But, jeez, you just can't play Purple Haze in open G!  I love D tuning too.
Easy solution here and Hoser got it rite.Stay with your standard 13's but change out the high E to a 14 and the B to an 18.I know it doesn't seem like much but if your going to play slide and finger notes this is a good compromise.I would also suggest a glass slide so you can leave the action as is.With glass you have a bit more control over the preasure you need to produce a clean slide note.
Thanks, I have been playing acoustic slide for a few years now and I really got to liking my brass slide.  The thing is so heavy it will break a toe if you drop it.  I also play with ceramic (Moonshine slides) and glass (Diamond brand) and the glass really seems to work well with my OMV-03 to my ears.
I really do want to keep the setup the same but I am swapping out my saddle for a new bone one so that may give me the opportunity to raise the action up just a bit.
If I were to formulate a custom set of strings with respect to the gauges, where do you all recommend purchasing? Are there any retailers that will build custom sets?  I typically use juststrings.com and I know they sell individual strings but I do like to buy them in sets.
Paul
OMV-03
Rhodes Mark 1
Paul, like I said previously, this is a compromise that you have to make in order to keep the strings from buzzing on the frets.  Just try switching strings a bit at at time.  Evaluate what strings play well with your current set up, as well as what strings seem to buzz, then raise the gauge of the strings that buzz on the frets.
It's a decision that you have to make from trial and error, that's really the bottom line.
I agree with your observation; the heavy brass or glass slides are really the best.
I ordered a few 14s and 18s to try them out.  Thanks for the advice.  I'll keep you apprised.
Paul
OMV-03
Rhodes Mark 1
