can you over buff your wood?well
Started by markanthony, August 20, 2005, 10:20:07 PM
you can buy pure carnuba at a woodworkers supply shop (and other places).
I am afraid that I have not any concept about buff,what exactly it is ?
But  I guess that it will take risk to do that.
Quote from: www.rocksoul.net on September 04, 2005, 08:57:17 PM
Rocksoul, what we are talking about is "polishing" a satin finished guitar. Tom Young aka Orsino was the earliest proponent of doing this and has done it on several Martin and Larrivee guitars. We now call it Orsinoizing in his honor.
Basically it is a 2 or 3 step process. Most of the products discussed are made by an Automobile wax and polishing products company called Meguiar's.
Step 1: this is to reduce the roughness of the satin finish. Tom now recommends 0000 steel wool lightly rubbed over the finish. I am apprehensive about the steel wool taking off too much finish and I have used Meguiar's Deep Crystal System Paint Cleaner or Step 1.
If I were to do it again, I would use Meguiar's Scratch X
Step 2: Meguiar's Deep Crystal System Polish or Step 2. Apply several coats and hand buff using a lot of "elbow grease" or in other words pressure.
Step 3: (Optional) When we first started doing this, we used Meguiar's Deep Crystal Carnuba Wax to protect the finish. Then we discovered that this product uses silicones which can interfere with refinishing the guitar should it ever need it. If a wax is desired find a good quality wax (Carnuba is usually considered the best) that does not use silicones.
Petros guitars has a polish with carnuba wax that they say does not have silicones in it.
Ask if you have more questions.
Don
Larrivée D-09BW
Larrivée LV-03BW
Larrivée OM-03K
Larrivée LV-03-12
Martin D-18 RIP :crying:
Mossman Tennessee 12
Gretsch Chet Atkins DC
Gretsch Tennessee Rose
Fender Am. Stratocaster
Guild X-170T Manhattan
Fender 90s Telecaster Custom
Guild Starfire 5
Gretsch 5422 12 String
G&L ASAT Deluxe Semi
Quote from: LaminateBoy on September 02, 2005, 04:47:03 PM
Careful, you might get splinters.
I always heard you might go blind if you overbuff your wood...
Thank you dbirchett ,Now I basically know the meaning of  buff
It should really only have to be done once.   Maybe go over it later with the step 2.  But from then on a damp cloth is all you should need.
If you wax it it can look funky in spots as heat and sweat remove or relocate the wax.   Wax can be easily removed with mineral spirits or better, naptha (lighter fluid) .  mineral spirits can leave awhite residue behind.
If you aren't "handy" the wool might be intimidating.  all you're doing is mowing down the particulate that gives the rough feel or swoosh noise, creating a better surface to polish.
Peter
creestudios.com
Art Guitars and more
