Larrivee Bridge Pins - Size?
Started by rpg51, June 06, 2005, 03:33:48 PM
I'm thinking of picking up a set of bone or fossilized ivory bridge pins (proly bone - ivory is out of my league).   I am new to this but my sense is that these pins come in different sizes - (dia., length, taper angle)???  Anyone know what size I need for an OM-50?
Rob
Bourgeois Vintage OM
Larrivee D-05 MT
I will make some exact measurements with calipers in a minute and tell you. Here is a nice explanation of pin sizes but this page has not been updated in several years so I would only use it as a general guidelines for sizes. The key is the 3 degree or 5 degree taper and length. Stewmac.com has good physical pictures of the specs of their pins. I hate their bone saddle material but they have some of the best bone pins I have ever bought. They sound like glass rolling around in your palm and are really dense and consistent. Allparts bone pins are more crude and also have the ball coming up too far in my opinion. I also ordered some ox bone and other style pins from GuitarGal that I personally dont care for. I sure have several kinds here in the package I wouldn't mind selling.
(click here) Bridge Pin Sizes
quote"A larger head profile with no skirt make these pins stand out on Dreadnought and Jumbo guitars. Available in Size 4.1 (3º tapered shaft) and Size 4.2 (5º tapered shaft). Larrivee guitars use a Size 4.1 slotted pin"unquote
My measurements on a new Larrivee just now... Which looks like a 3 degree taper.
1.030" or 26.2mm = total length of pin
0.810" or 21.1mm = length of shaft below the lip or collar
0.201" or 5.11mm - diameter just below lip or collar
0.163" or 1.27mm - diameter at the tip
P.S. I'd stick with the ebony. Bone second choice. Dont waste your money on anything more exotic IMO. Another idea would be skip this altogether and pay a good luthier or repair shop to slot the bridge for you then buy the Stewmac unslotted bone pins. Now that has a chance of boosting your tone, beauty and perhaps make a better guitar in my opinion. I love unslotted pins.
Check out my new blues site WEB SITE with free acoustic blues lesson videos and more.
Man what a world we live in.  Post a question and in half an hour you have the answer.  Thanks LittleBro.  BTW - I'm the guy that sent you that e mail last night.  Ordered your DVD last night.  Can't wait.
I agree on the fancy pins - its more a cosmetic thing for me.  I don't think it will amout to a hill of beans as far as tone improvement.  Hard to improve on the tone anyway, its great.
I don't know why, its probably silly,  but my minds eye sees waverly open back tuners with  iroroid knobs and cream colored bone pins with abalone dots on my little OM-50.  The white/cream will pull the whole thing together visually.  Silver tuner knobs and black pins don't mesh with ivoroid neck binding and light maple body binding - just doesn't do it for me. No symmetry.  I'll pick up some "inexpensive" bone pins - maybe at Stew-Mac.  The waverlys on the other hand - they will set me back a bit.  I am not all that impressed with the function/performance of the open back pings.
In all other respects the thing is a sweet little work of art in my judgment.
Thanks again.
Rob
Larrivee D-05 MT
LB, I just now understood your suggestion about slotting the bridge.  My guitar is going to a first rate Luthier in the Boston area in a few weeks to give it a thorough going over and a set up.  Should I have him slot the bridge?  Explain? What is this all about?  How much does it cost generally?
Rob
Larrivee D-05 MT
I just checked stew mac - all their pins are 5 degree taper.  Will that fit my OM-50?
Rob
Larrivee D-05 MT
Quote from: rpg51 on June 06, 2005, 04:34:11 PM
Well it's a simple job, they just take a little reamer that is the same angle as the pins and they slighty correct the pin holes if even required. Then they get those new unslotted pins fitting perfect and snug in those holes. Then remove them and use a keyhole file and slot the bridge right in front of the pin. The string will then rest in that slot. The trick is making the slot perfect and shallow enough so the string is still touching the pin, the wood and riding in that groove. If you acheive this solid connection you will have the best setup possible. This also increases the angle that the strings go up and over the saddle. So that is yet another improvement bonus. Then from now on you dont have to worry about getting the right pins back into the right holes. They will all be perfectly uniform. I am involved in the production of some high end custom guitars and they come standard this way but usually this is something you only see on professional guitars or high end small luthiers. It's only a 30-50 dollar upgrade and no big deal if you have someone great doing the work.
These are the pins we use and we also order the small reaming tool that matches them. These are the best bone pins I have ever bought and I have about a dozen kinds here in stock that I bought trying to find something good.
CLICKABLE LINKS BELOW
Bridge Pins I like
Saw that cuts the slots here
Bridge pin reamer tool seen here
See Frank Fords site with pictures and examples of the work being performed (site may be down today)
Tempting.  I think I'll get it done when the guy does the set up.  Should I have the new pins for him when I give him the guitar?
I wonder - warranty???
Maybe I should check with Larrivee?
Rob
Larrivee D-05 MT
Should not void warranty but of course Larrivee just wont repair any damage you cause by modifying the guitar. To be honest this is no different than having a new nut, saddle or fretjob. None of that voids a lifetime warranty. As far as buying the pins ahead of time it's usually a good idea unless you want to use whatever they may have on hand. Most of them keep bank bone saddles and nuts but probably wont have the pins you want. I'd check with them first then make sure they have the right tools then order the pins. Give the luthier or repair person the links I gave you above too. Good luck, this is not a big modification so as long as they are competent you are ok. Call Larrivee support if you have any concerns.
Doug
UPDATE
I decided to purchase some bone pins mostly for the looks - I want white/cream color, not black.  I recieved them from guitargal.com today.  Size 1 (not 4.1) as guitargal suggests for Larrivee.  She could not get the 4.1 size in bone.  She thought the heads on the size 1 pins were smaller than the stock Larrivee pins.  Turns out she was incorrect about this.  The size 1 (three degree taper) bone pins she sent me are exactly the same size as the stock ebony pins that came with my OM 50.
I decided against slotting the bridge - might do it in the future.
But these new pins fit perfectly and look very nice.  Also bought some waverly tuners with ivoroid buttons which I will have installed in the near future.  Then I'll be groovin with my OM-50!  When I get it all tricked out I'll post some pics.
By the way, I notice zero change in tone between the bone and the ebony pins.
Rob
Rob
Larrivee D-05 MT
  I'm interested in this modification (sloting the bridge for string fit).  If I understand what Litt'l Bro is saying, this might help tone/sustain IF there was a fit problem, but the REAL intent is to seat the stings to the bridge through the "new" slot in the bridge, so that the bridge actually holds the string end in place solidly, not the pin slot and taper fit?  This makes a lot of sense... never really thought it through.  With my "other" flat top, I've had problems when re-stringing, the pins had to be held in place until the guitar was tuned up, then all was well. (the tension then forced the string end to "seat".)
Much thanks for this tread and links, ...anyone know a good luthier in Western MD or Southwest PA? :huh:
Later,
Ed R.
Larrivee L-02
Larrivee D-02
Gibson CL-35 Deluxe
Alverez AD65CE-sb (Archtop)
Hamer Standard (Explorer) FOR SALE/Trade?
Romans 12:2
