Ebony or other wood tuner buttons
Started by rockin_ron, May 13, 2026, 03:56:48 PM
I'm looking to dress up an older Larrivee guitar a bit and take some weight off the headstock.  Does anyone know which manufacturer/supplier has real wood (ebony) tuner buttons that are a direct replacement to fit on Larrivee tuners?  I know older Larrivee's used both Ping and Schaller tuner bodies, not sure about the current builds.  Problem I'm running into is most retailers and eBay sellers carry Grover replacements and either don't know if they are cross compatible or they're not interested in taking a few dimensions to verify.  I don't want Larrivee's because they are fake wood or ebenoid, basically plastic.  If you've done a mod like this and you have that information and maybe a pictures that would be great.  Thanks!
Quote from: rockin_ron on May 13, 2026, 03:56:48 PMI'm looking to dress up an older Larrivee guitar a bit and take some weight off the headstock.
If you're still spitballing ideas, have you thought about replacing all six tuners with open-back tuners? I did this a while back on my OM, and it did make the neck lighter. If you're handy with such things, it's not that difficult of a procedure. I'm happy with how mine turned out.
Be aware that changing headstock mass can alter the sound, the wolf notes, etc. The stock tuners aren't particularly heavy and I don't see getting an appreciable gain as far as weight goes. I'd really only recommend it if you don't care for the look or the function of the stock tuners. I've done it on a couple Larrivees. Had to fill and re-drill a few holes. I believe there are some drop-in types though.
Only looking to change the buttons more for look and aesthetics.  Eliminating the weight of chromed metal buttons is just a plus.
Quote from: rockin_ron on May 13, 2026, 05:03:10 PMOnly looking to change the buttons more for look and aesthetics.  Eliminating the weight of chromed metal buttons is just a plus.
Ah, thanks for clarifying. When I looked into it a while back, there wasn't an easy replacement. But, that could have just been the particular versions of Larrivee tuners I was trying to swap buttons on. Hopefully someone here will have better news.
https://www.larrivee.com/shop/black-aluminum-buttons
Larrivee OM-03, OM-03 laurel, OM-50, L-03 laurel, LSV-03 Forum VI, 000-01
As Mike suggested, I bought a couple sets oof the black aluminum buttons and I really like them
Herman
L-10, L-03 Custom shop Flamed Maple, OM-05, Forum VI, Forum VII.
And *others*
I was lucky enough to get some from a local luthier. Slightly older Gotoh with custom buttons on my C-09W.
https://share.icloud.com/photos/02bk3aeQyrQOqOe_izC3eNRdw
Even going gold buttons looks like quite a good upgrade, and you can stay with Larrivee tuners too.
Quote from: Michael Howard on May 14, 2026, 04:39:07 AMI was lucky enough to get some from a local luthier. Slightly older Gotoh with custom buttons on my C-09W.
Looks nice with the wood buttons.  That is look I'm going for, the wood nicely accents the guitar.  Problem is finding them and ensuring they'll fit on the stock tuner posts.  Grover 1020E Ebony buttons suppose to fit on Larrivee based on ChatGPT.  The problem is nobody seems to carry them anymore or they are all out of stock.
Quote from: rockin_ron on May 14, 2026, 07:31:18 AMLooks nice with the wood buttons.  That is look I'm going for, the wood nicely accents the guitar.  Problem is finding them and ensuring they'll fit on the stock tuner posts.  Grover 1020E Ebony buttons suppose to fit on Larrivee based on ChatGPT.  The problem is nobody seems to carry them anymore or they are all out of stock.
When using AI, look at the source that it is citing. AI is often inaccurate when talking about parts compatibility. I know because I use it for business every day. But, you can see where it got it's info and decide if that info seems valid.
I can't tell you the number of times AI gave me info that turned out to be something it pulled off an old forum post where some yahoo gave bad advice and, even though people corrected that person in the thread, AI still took it as a correct statement. This is because AI can't reason. ChatGPT is one of the worst so use Gemini when you can.
Gotoh 501 3+3 midsize tuners were drop-in replacements for the original Larrivee Ping tuners. They hold tune better and they now come in 1:21 gearing. Not sure how old your Larrivee is but I changed out my 2001 and 2002 Larrivees with the 510 1:18 gold with black button 510s for under $100 but the Ebony buttons are more. Not sure if you don't want gold but it sure dresses it up.
  Here's a link:
https://guitarhey.com/search?q=Gotoh+501+gold+ebony+buttons&options%5Bprefix%5D=last
I think that site is the Gotoh importer but  Stewmac has ones with black button on sale:
https://www.stewmac.com/parts-and-hardware/tuning-machines/solid-peghead-guitar-tuning-machines/gotoh-midsize-510-33-tuners-with-custom-knobs/?gad_source=1&gad_campaignid=23390037119&gbraid=0AAAAAD-EellqpC-P_kZfQof748xhbe786&gclid=EAIaIQobChMI8cajjpHflQMVx0t_AB1ZlA7YEAQYASABEgKRsvD_BwE
Larrivee 2001 DV-10 Koa  LR Baggs active Ibeam/dual-source Crown GLM 200 mic
Larrivee 2002  C-10 Koa LR Baggs Anthem SL
Larrivee 2015 000-40 MT large soundhole LR Baggs active Ibeam/passive Baggs M1
Composite Acoustics Cargo LR Baggs Element/dual source mic
Quote from: Koamon on July 19, 2026, 12:24:02 PMGotoh 501 3+3 midsize tuners were drop-in replacements for the original Larrivee Ping tuners. They hold tune better and they now come in 1:21 gearing. Not sure how old your Larrivee is but I changed out my 2001 and 2002 Larrivees with the 510 1:18 gold with black button 510s for under $100 but the Ebony buttons are more. Not sure if you don't want gold but it sure dresses it up.
  Here's a link:
Thanks for the help and these links.  Not really looking to change out the tuners, just dress up with the ebony.  Looks like Stewmac have the large M-6 Schaller buttons in stock and on sale currently.  I checked with ChatGPT and gave it my chrome tuner button measurements (0.141" across the flats and 0.159" on the insider diameter of the hole) and it said they should fit with over 95% confidence.  Told it was marked Larrivee on the tuner and it stated they were very likely either Ping or Schaller for that era build.  These buttons have been really tough to find because every other place I checked showed them on there website but they were all out of stock.  Even this Guitarhey you mentioned was also out of stock. Sounds like it is worth a shot.  Appreciate the help!
I replaced the tuner buttons on my Forum VI with walnut ones made by Charis Acoustic. They were very close to an exact fit and the only slight modification I did was to ever-so-slightly enlarge the holes with a drill bit.
Larrivee 000-03 Forum VII
Larrivee LS-03WL Forum VI Limited
Larrivee OM-40M
Larrivee O-01W
Taylor AD12E
Martin 000-16 (gone for now)
Epiphone Olympic Solid Body Electric (1967)
Larrivee F-33 Mandolin (8/1/2008)
Larrivee A-33 (8/21/2009)
Kawalek Octave Mandolin
Eastman MOD 305 Octave Mandolin
I replaced the buttons on my 2004 L03 with some snakewood ones from eBay. They said they were for Grover's, but fit really well.
2026 Forum VII
2004 L-03
Quote from: jasonchamb on July 23, 2026, 03:13:02 PMI replaced the buttons on my 2004 L03 with some snakewood ones from eBay. They said they were for Grover's, but fit really well.
Interesting,  I bought ebony tuner buttons that said they were for Grover (part # 1020E) on eBay that were suppose to fit and didn't.  The hole was too large and sloppy for the shaft.  Didn't work and I wasted $35.00.  Care to share the eBay supplier and PN that you used?
https://www.ebay.com/str/naturalmusicshop
It was from these guys. They have snakewood and ziricote bocote. I was naturally skeptical, but the cheap price was worth the gamble.
2026 Forum VII
2004 L-03
Incidentally I also replaced my Forum VII tuners with some black JCL 18:1 tuners I found in the wild for significantly less than the retail rate.
2026 Forum VII
2004 L-03
