Help! Warranty Question
Started by silvertone62, November 30, 2013, 09:49:20 PM
Hey fellow Larrivee aficionados, it's been awhile. I still own my two Larrivees, a 2000 P-01 Koa Parlor and a 2004 OM-03mt. I've enjoyed both guitars immensely, and
for a guy that hadn't owned or even played, a Larrivee 3 years ago, 2 of my 4 acoustics are now Larrivees.  What great instruments!
My 2004 OM-03mt was a NOS guitar and was just fine when I took delivery about a year ago. It's sound bloomed while at the same time I noticed its neck began making a turn(literally) for the worse, and it  became unplayable. It was way beyond adjustment.
First of all, full disclosure: I live in the Nashville area, I was in the playing end of the Music Business for over two decades, and have owned dozens of acoustic guitars. My main repair guy here is very well respected and knowledgeable . I brought the guitar to him, saying nothing to him about the nature of the OM's issue, and after a couple of minutes of inspection he placed it back in the case and said those dreaded two words - neck reset. I've had  neck resets performed on at least a half dozen guitars, but they've all been on older guitars that needed a neck reset at 10-12+ years of age. They aren't fun, kind of like a root canal on your wallet.
Reader's Digest Condensed version: It was under warranty, I contacted  Larrivee, they sent me a Return Authorization, I shipped it to them, they acknowledged receipt,
and it's been going on a 100 days now with no word and certainly no guitar.
Question: HOW LONG DOES IT USUALLY TAKE? I really miss that guitar. Should I be concerned?
I'd say that's a long time, even for a significant repair like a neck reset.  You need to contact Larrivee (by phone, e-mail or both) and find out the status on your repair. If you e-mail them, you need to use the word 'GUITAR' in the subject line of your e-mail to get it past their spam filters. But in this case, I would also get a phone number and call.
Matthew Larrivee monitors these forums somewhat - maybe he'll see your post and respond.
1999 D-02 Left-handed
2002 L-05 Left-handed
Larrivee owner since 1992
Thanks,  I'll call them on Monday. I would think that if they weren't going to cover this on Warranty they would have sent the guitar back to me by now.
I really miss that guitar. A great player and the perfect instrument for fingerpicking/hybrid picking recording. A solid strummer, too....
Quote from: silvertone62 on November 30, 2013, 09:49:20 PM
Hmm that does seem odd. I'll look into it for you.
** I am not familiar with your guitar at all, so the following is not necessarily about your specific guitar ** The vast majority of neck angle issues that we come across are not the result of too-much string tension. This is a VERY common misconception. Luthiers tend to know what to look as far as determining if neck angle is out, but rarely are they able to determine the cause. The vast majority of cases that I see are the result of the too-much / too-little moisture in the guitar back. Normally the back is arched but when the moisture content changes, the back flattens (dry) or becomes more arched (wet). When this shrinkage / expansion occurs it pulls the neck block along for the ride. In the case of over humidification, the neck block tilts forward which pitches the neck forward and raises your action a mile high. In the case of dryness the neck block is forced inwards, pulling the neck back. This change can be dramatic on any guitar. I recently got a 45th anniversary guitar back from someone in a wet state (Washington I think) and the gentleman had also been using a humidifier. The guitar came in with the fingerboard plane 4mm below the top of the bridge. The RA said "bad neck angle, needs neck reset". Our default protocol on a guitar like this is to first let it sit in our climate room for several weeks to normalize. In the above case, after we removed it from the climate room the neck angle was spot on (fretboard plane kissing the top of the bridge). It is virtually un heard of with our instruments for the neck to go from a normalized position for any other reason. In your statement above, you mention that "It's sound bloomed while at the same time I noticed its neck began making a turn(literally) for the worse".. a guitar that is more than a few months old (i.e. a settle in period) that was once playable, but slowly changed needs to be examined closely for the above.
Like I said, im not yet familiar with your specific guitar - but it may well be that it was determined the first course of action should be normalization of moisture. Whatever it is, waiting 100 days is too long and we need to remedy it for you.
ML
Thanks for the lesson Matthew. The forum III I purchased recently was obviously swollen with humidity and the action was high. I took the strings off and let it rest and dry out for two weeks. After about two months now and some action work on it, plays and sounds great. The only problem with it is the fret ends are slightly lifted. Any suggestions anyone? I can live with it if it doesn't change.
A Hebrew, under the Spell
Pain is a good thing
Quote from: broKen on December 01, 2013, 01:43:33 AM
Are the fret ends actually lifting up out of their slots?  If they were, I would think you might start to get some buzzing that wasn't there before.  Especially if you had it set up for low action already.  I'm wondering if the fretboard has dried out to the point where the fret ends are sticking out and you can feel them when you play.  If it's the latter, you can file (level) the fret end bevels back a bit.
Hope this helps.
:guitar
Quote from: L07 Shooting Star on December 01, 2013, 03:35:30 AM
Hope this helps.
Ever so slightly. What drew my attention to it was that I could easily feel the ends of the frets snagging my skin. The frets do not stick out beyond the neck binding,  but the very ends are up off the binding enough that the sharp ends can snag. I looked closely with my magnifier and can see the gap and some grime under the fret. This guitar was badly over humidified when I received it almost two months ago.
Maybe try pressing the fret ends down with a finger or a dowel to see if they might stay down.  Using your magnifier, see if you can move them down with pressure and if they pop up again when you relieve the pressure.
:guitar
Interesting thread to learn from.  To the OP, I am sure Larrivee will set it straight (pun inntended :winkin:)
Matthew- thanks for the reply! I'll give you a shout on Monday. I live in Tennessee, which shares the dampness of Burma in the dead of Summer. My guitars are kept in
a climate controlled room, but it's a long war when it comes to defeating Humidity.
Thanks for the excellent explanation.
If the fret ends are evenly exposed down the neck were they over the binding then you've got some binding shrinkage.You need to have them rolled down towards the binding then have the edge's rounded,which solve's the problem.Find a tech who know's what he's doing and have them do the job.
Quote from: L07 Shooting Star on December 01, 2013, 04:44:35 AM
I did that soon after receiving it. They do not move. After letting it dry out for a while I tried again, even tapping them with my tack hammer. No movement.
Quote from: unclrob on December 01, 2013, 12:17:23 PM
Thanks Rob, I think you may be right. The frets are the same along the entire neck. I believe I'll just live with it before I pay someone to screw up a fine guitar. If anything I'll see to it myself.
Thanks to both of you for your responses and advice.
Don't use a tack hammer,use a plastic,hard rubber or rawhide one.Wait about 3 weeks then using a push off motion on each fret until the fret sits on the binding,just do the ends not the hole fret.After that's done you'll need a small file {check stew-mac} to round the ends.
