Sanding bone pins for diameter and taper?
Started by CJ, August 17, 2013, 06:31:13 PM
A new set of bone pins from an eBay seller I've used several times before, vary in size such that one of the pins is 3/8" from seating in the string hole. The 5 that do push in all the way, are quite snug. To remove them, requires a bit of prying. The pins were advertised as size 1T, which per the charts, are correct for the 2001 Tacoma Chief I just got.
So I'm puzzled what to do.
Do I sand the pins with a fine grit to make them fit better? Or gently enlarge the holes with a fine grit paper wrapped around one of the old pins?
I can't imagine it would take more than a few twists in sandpaper to narrow the diameter of the pins, but really don't know how snug they ought to be. Is there some measure / standard for how snug/loose they ought to be?
The specifics follow, if of any interest/value.
Using a caliper to measure all 6 of the new bone pins, the diameter below the skirt varies from .194" to .202" and the diameter at the pin end is .152" to .164". The underskirt diameter suggests something closer to 1.3T. I calculate the taper at about 2 degrees. These are the pins that fit snugly, obviously because of the 2 degree taper.
The Tusq pins the guitar came with have a .207" under skirt diameter and measure .145" at the pin end, which works out to a 3 degree taper. Though larger at the skirt, the taper lets them slip into the holes so far they can be difficult to remove. They measure up like 1T pins except for the whole 'sliding too deep into the hole' thing.
Start with 400 grit and do full twist in your hands,always check them in the pin hole's.when real close move up to 600 grit then finish off with 0000 steel wool.Just take you time and don't squeeze the pin too tight in the sand paper.
Some builders go so far as to size each pin for the individual string, so that the trebles and basses fit nicely. Up to you whether to go that far.
However, probably better to shape the new pins than to permanently change your guitar's bridge plate hole sizes
Quote from: RoundLakeDT on August 18, 2013, 01:21:56 AM
:+1:
My assumption would be that the holes in the bridge are consistent and the common denominator, so I wouldn't mess with them at all.  So any tweaking you do should be to the pins.  Do like Unclrob suggests.
:guitar
Quote from: L07 Shooting Star on August 18, 2013, 04:25:08 AM
:+1:
That makes sense; after posting I tried each pin in every hole and there is just the 1 that is too large. So I'll sand that one down some, the others will get a turn or 2 as well so they're not quite as snug. That's just never happened to me before - the half dozen other pin sets I've bought from the guy are more consistently sized with no fit issues at all.
Also priced tapered reamers and there are few choices in a 3 degree taper - the one I did find at Stew Mac was about $60! Sanding the pins is much less expensive.  :bgrin:
Do I have to?  :humour:
Well, after a little more reading, I found someone who suggested using the tapered end of a file to clear the holes in a guitar - going slowly and gently, the low E through B holes were consistent and clear - but the high e was tight. Rotating the file was sufficient to clear the hole of whatever obstruction that reduced its diameter / taper.
An hour of sanding with 150 and 220 grit, got the pins all to a more consistent size, each pin fit checked in each of the 6 holes.
Then took one of the Cherokee bone saddles and matched it to the existing saddle - which was good for height - and dropped it in. Thank God for a belt sander to make quick work of getting it near to the right height. A file and some 220 grit finished it up.
What a nice sounding and fun little guitar that Tacoma Chief has turned out to be! Downright snappy with bone pins and saddle!
 :nanadance :nanadance :nanadance :nanadance :nanadance Gotta love a good belt sander  :nanadance :nanadance :nanadance :nanadance
