Modding a digital piano/keyboard output to match input level of guitar amps.
Started by L07 Shooting Star, August 02, 2013, 12:38:45 PM
Maybe you electronics experts can help me on this.  We  have been using an older digital piano/keyboard for our band rehearsals for a couple of years.  It does not have any "line level" outputs on it but it has two headphone out jacks.  The keyboard only has a master volume that controls both the level to the built in speaker, and the headphone jacks.  Plugging in to any one of these jacks automatically turns off the speaker.  Up to now we have been taking the output from either of the headphone outputs and plugging it into any number of regular guitar amps.  I know enough about electronics to know that the output level we are sending is much too high.  It works, but only if the volume on the keyboard and the amp. is turned to a very low setting.  We can get all the volume we need and more this way, but we are obviously overloading the guitar amps input.  Not only that but the settings are much too sensitive and turning one just a bit too far can blast you out of the room and I suppose blow something in the amp. if it gets too loud.
I would like to attentuate the signal from one of the headphone jacks to a suitable level.  My idea is to build a little circuit box (or maybe just buy one) with an input and output jack and the appropriate electronics inside the box.  Ideally, it would have an adjustable output level, but not necessarily.  A simple in and out would be OK if it provides the proper output level and doesn't introduce distortion.
Any suggestions?  What parts would I need?  Would a guitar pot work maybe?  What is the best solution to provide a nice clean signal at an appropriate level?
Kurt
:guitar
Most standard DI/attenuators are set up for a 20-40 db cut.Most also have a 1/4 in with a XLR out.This should do the job.I'm still hunting for some that has a adjustable output.This should solve the problem.
