Saddle Thickness For An Lv-05
Started by damianip, January 05, 2005, 02:29:40 PM
I was thinking of trying my hand at shaping a compensated bone saddle for my new LV.
Anyone know the saddle thickness? I'm guessg 1/8". I'd like to order a couple of blanks, and I'm not home to measure one right now.
TIA,
Paolo
"Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. "
Bil Mitchell HG 00 -  all Walnut
Everett Laurel O
Larri LV05MT
Larri LV09 Custom All Walnut
Larri LV-03RE-12
Larri J05
Larri SE Parlor Walnut
Tacoma C3C - peeling finish
Martin 000-17
You might do better to get one from Bob Colosi www.guitarsaddles.com
The top of the saddle is already shaped, with the compensation for the B string.  All you have to do is fit to your guitar.  They come with instructions on fitting to your guitar.
Bing
Larrivee J-09FM
Taylor 814ce
Music Man Axis SS w/piezo
Actually, I've done some for resonator saddles out of maple, and others out of plastic (Tusq and cheaper stuff) for lesser flattop guitars. It took time, but it came out well.
I figure I'd give the bone material a try myself. Bob's saddle for a Larry is about 20 USD with postage. Bone blanks are cheap. It may not be as nice as Bob's, but I'll consider it a learning experience.
If all else fails, I'll go to Colosi or Larrivee to save me. (or just put the Tusq saddle back and play the guitar...)
Paolo
Everett Laurel O
Larri LV05MT
Larri LV-03RE-12
Larri J05
Martin 000-17
They are about 1/8", but every saddle slot is a little bit different.
Bing
Larrivee J-09FM
Taylor 814ce
Hey damianip.
Bing is right: every saddle slot is different. And mine, I discovered, is wider than the CNC cut bone saddle that I bought directly from Larrivee.
My Larrivee bone saddle wasn't sitting in the slot nearly as tight as I knew it should be. Which is the reason I decided to get a bone blank and make my own  saddle.
I went to my local repair girl, and rooted through her stash of bone blanks for the widest 1/8" bone blank I could find. (I say "widest" because they're often not cut super accurately, and you can always sand the blank to fit. That said, don't go with anything too thick, or you'll be sanding all bloody day.)
After screwing up my first attempt (my saddle radius was a llittle too flat, resulting in some unecessary buzzing on the third, fourth and fifth strings), I nailed it: an exact replica of the original Tusq saddle, with the boxy compensator. I used a regular rasp file for most of the work, plus a tiny metal file to finesse the B-string compensator. Then, after I was satisfied with the curvature of the top, I sanded down the bottom with sandpaper affixed to a glass tablle top. Honestly, it looks exactly like the original.
But do make sure that you correctly shape the top of the saddle. That, IMO, is the trick.
Bob Colosi makes all of his saddles a little wide and thick.   So that's why they must be fitted to the saddle slot.  I don't think I could get as accurate as he does on the saddle top.
When I bought the J-05 someone had attempted to shape a bone saddle, but did not do a good job.  My replacing it with one of Bob's saddles, it made all the difference.
Bing
Larrivee J-09FM
Taylor 814ce
