More Larrivee pickups (bwa-ha-ha!)
Started by Mikeymac, June 14, 2012, 09:57:01 AM
So I just dropped another set of Larrivee humbuckers into one of my guitars! I'm mad, I tell you - MAD!!!  :humour:
When I pulled the EMG's from my recent SG purchase, I traded them with igreshenko on this board for a set of Larrivee humbuckers, and also bought a set of Larrivee P-90's from him for future use.  I learned that he's a Larrivee employee at Oxnard - how cool is that!?
So I pulled the set of Seymour Duncan JB and Jazz pups that have been in one of my Warmoths for YEARS ... and also reconfigured the controls, adding one more, so now the guitar is volume/volume/tone, with a 3-way blade switch (but note the Gibson-style switch tip).
I did this because these Larrivee buckers just have a lead and ground wire, so no fancy coil splitting, like I had with the JB/Jazz set. Adding the other volume control gives it some of that flexibility of slightly rolling off one volume in the middle position for those Gibson "middle" sounds.
How do they sound? Very good - not as hot as the JB set, and also not as woofy on the neck pickup. Like my other Larrivee pups, I have to describe the sound as "honest" - you can't hide sloppy playing with these; you have to be on top of your technique.
(I also cut a new bone nut for the guitar - I'd been using one stolen from a cheap guitar. With moderate use of the Wilkinson VS100 trem, this thing stays in tune great - much better than other non-locking trems I've used.)
Here are some pics:
1999 D-02 Left-handed
2002 L-05 Left-handed
Larrivee owner since 1992
And one before and after shot. In the before shots it has a different neck (maple/pau ferro board) and gold hardware, hence a different (cheaper) Wilky trem - the VS50 (which does not stay in tune as well as the VS 100):
Way cool..I like the Gibson style switch tip,is it just pushed on or did you have to mod it?If this helps I discribe Larrivee humbuckers as musical and for me the only other musical pu's are Lindy Fralin's and Kent Armstrong's.I also like the 2volumn and 1 tone wiring.
So how does the SG sound...? :wave
Quote from: unclrob on June 14, 2012, 10:16:22 AM
unclrob,
I had to mod it slightly - i used a small nut file and cut a couple grooves inside the hole, so that there is now a 'slot' to line up with the switch's blade ... works great, and it stays on nice and tight. I was pleased with how that worked.
The SG sounds great - brighter than an LP, as you would expect, but with more openness and clarity than typical Gibson pickups (more of that 'honest' tone coming through!). I'm very happy with it, and will probably be taking it with me to a band practice I have tonight - so many guitars to put in rotation, so few gigs (I want to play them all!).
Speaking of more guitars ... I have another Warmoth body that's been sitting around for over a year - it's a mahogany LP Special (doublecut) routed for 3 P-90's and a wrap around bridge (which I also bought from Warmoth - a Gotoh). It will have 1 volume, 1 tone and a 5-way blade switch - so basically a strat set-up with the 3 P-90's.
I want to put a finish on it pretty soon, buy one more Larrivee P-90 pickup, and put together yet another left-handed masterpiece!
(Picture of the Gotoh wrap around bridge:)
Some thing you might want to try is to put in a standard 3 way switch and put the middle pu on a push/pull so you can turn it on and off.You'll get so many more tonal variations.I wired up my 3 pu tele this way with a mini toggle.Now I can get the standard tele sounds like neck/bridge and also get the use of all three pu's plus all the standard strat sounds.
Quote from: unclrob on June 14, 2012, 12:33:58 PM
Good idea!  :thumb
I'd probably use a push pull pot for the tone and avoid the extra switch hole that way...
 :nana_guitar Another convert............ :ohmy: did I say that outloud.......... :wave
Actually, unclrob - not to burst your bubble or anything - but I have pretty much that set-up on this Carvin (pic below) using the neck tone knob as a volume knob to add in the middle pickup anytime. So the set up is neck volume and bridge volume like usual, the bridge tone is a master tone, and the neck tone adds the middle pickup in any position.
 :ohmy:     "CR*P".......
Mikeymac, that is some really purdy wood.
Quote from: Mr_LV19E on June 15, 2012, 11:06:36 AM
It sure is!!!  :drool:
Where are you getting the Larrivee pickups? Thought they weren't sold without a guitar under them.
Kenny
Quote: "You know, all things considered, we are very, very lucky to have all that we do, an embarrassment of riches, actually."
Quote from: tulk1 on June 20, 2012, 03:21:24 PM
I'll PM you...
Here's all three of my HxH guitars that have Larrivee pickups in them right now - gotta say, they all sound great!
(Also posted this pic over on the Larrivee Facebook page.)
