Finishes on Larrivee guitars
Started by DPprofessor, August 23, 2011, 05:46:25 PM
Does anyone know what kind of finish Larrivee uses, and whether this finish can be damaged by contacting the foam rubber on a guitar stand?  I know that nitrocellulose finishes can be damaged.  What kind of finish does Larrivee use, or did they use back in the 90s?
Martin D-28
1994 C-10 Custom "Mermaid"
1990 L-19 "Eagle"
Recording King ROS-626
Takamine EF360C 12
American Standard Strat
American Vintage Tele
Quote from: DPprofessor on August 23, 2011, 05:46:25 PM
I'm not 100% sure what they use, I think it's polyester but I'm pretty sure they don't use nitrocellulose.  Either way, just put some old t-shirts or towels over the foam rubber parts of the stand, problem solved.
UV light cured poly finish.  Your guitar stand should not be a problem.
https://soundcloud.com/247hoopsfan
1971 Yamaha FG200 (My original guitar)
1996 Yamaha DW5S
2002 Yamaha LL500
1990 Goodall Rosewood Standard
2007 Larrrivee JCL 40th Anniversary
1998 Larrivee OM5MT
1998 Larrivee D10 Brazilian "Flying Eagle"
1998 Larrivee D09 Brazilian "Flying Eagle"
Quote from: Matthew Larrivee on October 17, 2010, 07:24:54 PM
The first guitars were sprayed with hot laquer, and around '84 we changed to a modified Polyurethane varnish - Great stuff. We used that up until around 1995 (i think) when we started messing with Crown Metro's UV polyester. There were problems with crown metro and eventually we ended up using the MCfadden UV polyester. Mcfadden recently went bankrupt and we have switched to a new UV finish - which is relatively problem free and made locally in california.
Edit: The modified polyurethane was catalyzed. Up until 2 months ago the UV was not catalyzed. Now the UV is dual cured with partial catalyzation with cobalt & peroxide, and UV light
