Replacing the nut
Started by bbb, July 07, 2011, 04:18:21 PM
Hi folks, simple question: Could an average musician replace a nut when it´s glued to the fingerboard (like it is in my Larrivée), or is this best only left for the techies and luthiers? I´m not sure if my PV 09 E is bone or Tusq. Have a feeling it´s Tusq. Thanks, Bruno.  :donut :donut :donut2 :coffee
More than likely tusq, and best left to a tech, but, if you replace both you can intonate each of the strings almost perfectly and your open strings in your chords will resound with more clarity and blend. Most hacks like me won't mess with the nut so we minimize the effect because we can't do it ourselves.
08 Larrivee L05-12
02 Larrivee DV-09
73 Granada Custom
Kids got the others  :)
Bruno I know you stuck without a tech so here goes.CAREFULLY take a razor and score the nut on the headstock side along the bottom of the nut,then do the same on the fingerboard side.Also score the sides were the nut meets the finish.I use a flat head screw driver and gently tape from the fingerboard side.it will loosen up enough for you to pull it out.SAVE the old nut to use as a template for shaping the new one.As always if I can help you have my email. :thumb
