When did OMs change to 1 3/4" neck?
Started by lmacmil, June 27, 2011, 08:16:03 AM
Someone responded to my post on OM-0x models stating that older ones were 1 11/16" necks.  Anyone know when they changed?  I am looking for an OM and want a 1 3/4" neck.  If I end up buying used, I want to be sure I'm getting the wider neck.  Thanks.
That would have been me.
The early -03 series guitars had 1 11/16" necks.  The -05 and -09 have been 1 3/4 for as long as I can remember.  I'm not certain when they changed.  I am reasonably certain that any that are new enough to have wood binding should be 1 3/4.
I have a 1998 OM05-MT that has 1 11/16 neck, so it must have been after that.  The ebony headstock overlay has a glossy finish too,  while newer ones are matte finish.  The gloss is a nice touch. :winkin:
For what it's worth, I don't find the 1 11/16 neck an issue.   I also have  JCL 4oth Anniversary model with 1 3/4" neck.  They are both easy to play.
https://soundcloud.com/247hoopsfan
1971 Yamaha FG200 (My original guitar)
1996 Yamaha DW5S
2002 Yamaha LL500
1990 Goodall Rosewood Standard
2007 Larrrivee JCL 40th Anniversary
1998 Larrivee OM5MT
1998 Larrivee D10 Brazilian "Flying Eagle"
1998 Larrivee D09 Brazilian "Flying Eagle"
I think there wasn't complete consistency in the necks on OM's pre-2001, and then for the early OM-50's also.
best to have a seller measure for you if its an issue.
My '92 OM-05 has a 1 3/4" nut ...it's on the thin side of 1 3/4" and the neck is nice and thin compared to some current Larrivee's, but it's definitely 1 3/4".
1999 D-02 Left-handed
2002 L-05 Left-handed
Larrivee owner since 1992
My early 90's OM is 1-23/32" at the nut.
Quote from: Mikeymac on June 27, 2011, 11:19:30 AM
I just got a GAS boner from your 92 OM.  :whistling: :crying: :rolleye: :humour:
2001 Larrivee O-01
2008 Larrivee L-03 SP (All Sapele)
2010 Larrivee SD-60 Natural
1949 Gibson 125 (haunted with tremendous MOJO)
1978 Gibson "The Paul" (First Run solid WALNUT)
1970 Yamaha FG-300 (Red Label Nippon Gaki)
1972 Yamaha FG-240 (Red Label Nippon Gaki)
1977 Univox Hi-Flier Bass (sunburst, short scale)
1975 Harmony dreadnaugh
With the exception of fractions, I slept through most of my arithmentic and math classes. I own a Larrivee Parlor and LV-03 12 string and two Martins and all four guitars have a different neck width.
I don't think that the 1/16th inch variance between the 1 & 12/16 (3/4) low profile neck on my OM-35 and the 1 and 11/16 "C" neck on my D-35 make a discernable difference. I think the real difference in feel and/or playability comes from the shape of the necks which are all different.
Quote from: teh on July 02, 2011, 03:38:20 PM
Depends on person really -  even with same neck shape it's a make or break for some very experienced & gifted players that I know. Tho not make or break for me I have my preference BUT then again I am far from gifted :wacko:
Quote from: joshuaplucky on July 02, 2011, 07:46:12 AM
Thanks ... it's been my #1 acoustic for almost 20 years now...even though I've owned several other Larrivee's (and other acoustics) over those years...
