Buying a used D03 with a neck issue
Started by billfinch01, February 05, 2011, 10:31:54 PM
Hi all, Im looking at a used D03 in a local music shop. I know absolutely nothing about larrivees, but this one sounds great. The issue is that the saddle is very low. The action is alright (I would be happy with it), but I wonder how much more its going to change. The guy that owns it is a luthier in town and claims that the top is not coming up and he doesnt think that it is going to get any worse. He did however offer to modify the bridge If I wanted to further down the road. The price is $630, which I would not blink at if there were no issues (not because I have a lot of money, which I dont, it just sounds that good). I don't have any musician friends or anyone to bounce this off of, I would love to hear from someone that knows more about it than I do.  :donut :donut2 :donut :coffee
HI Bill. If the environment is dry now and the top is relatively flat, what will happen in more humid conditions and the top swells a few thousands. I would rather see it before offering an opinion. Also, have a look at the neck for relief (forward bow).
A Hebrew, under the Spell
Pain is a good thing
Thanks Broken, The environment is really humid here (Juneau, Alaska), I wish that I had thought to take a picture of it to put on here. There is some neck relief (a little more than my current guitar). I hate to sound stupid here (keep in mind Im just learning about this stuff), but what does neck relief tell me in relation to the low action/neck angle issue?
Thanks again
Neck relief only really tells you how much bow is set for the neck.Though with too much neck relief the action will appear higher its not really meant to set action or judge neck angle issue's.I will assume that by suggesting to modify the bridge he's thinking of popping it off and taking some height off the bottom then reglueing.Which will change the way the angle of the neck hits the bridge.Most say that it changes the tone of the guitar by doing this but I have done quite a few and have not heard any complaints.I would have him check the neck angle to be sure that that is the problem.As of late I've notice that bridge's appear to be getting taller from most companies,why I can't say but its what I've noticed.In the old days the bridge would have been shave from the top and the saddle slot routed a little deeper.
Bill, what Rob says is correct, that is, that adjusting the truss rod (changing neck relief) is not THE WAY to change action. But it can make minor changes in some situations. For example, if the action is a bit high and the neck has to much relief, tightening the truss rod A LITTLE BIT flattens the neck bringing it up closer to the strings. But if the action is high and the neck is flat, then some other adjustments must be made. A LITTLE BIT equals 1/8 of a turn usually. Forgive me for being elementary here, but if you are new to the instrument, you may not be familiar with the concepts. Hope this helps.
Ken
Great, thanks a lot guys. I really appreciate the input. Does that price seem in the ballpark to everyone? $630 without a case.
Bill
I would wary, if it were me.  A low saddle, to me, is a telltale sign of a non-optimal neck angle.  I like to see reasonable, low-medium action with a good, healthy ~1/8" saddle height.  If you find the action just OK now, there is really nowhere to go but up with a too-low saddle.  I would wait for the next ~$650 D-03, and chances are very good it will be fine.  One will come around, if you are patient.
BTW, based on what I have seen over the last 7-8 years, this is not really a new or unheard of problem in Larrivees.  Most of them come out very good, with a very optimal setup, but a certain few do not.  I once owned a D-03R with the same problem you describe - neck straight, top flat, but the neck angle too shallow, and the saddle had to be as low as possible to compensate.  I started seeing brand new larrivees in guitar shops with really short saddles, which just should not happen.  My guess is that these necksets passed the acceptable range based on factory standards, and were given low saddles during setup.  But it is not a good situation for a person who owns the guitar 5-10 years down the line
Thanks acousticphd, I got pretty excited about this one because there is only one music store in town and they only carry Ibanez brand new (which I have a hard time warming up to for some reason, some people say good things about them), and used only rarely (this is the first used guitar I've seen them have in 2 years, it belongs to the shop owner). Getting to another music shop requires an airplane ride or ferry followed by hours of driving. But, I would still rather save and get something decent someday than get a troublesome instrument now. Im glad I found out about the larrivee guitars, I'm pretty intent on owning one now that I've played that one.
Bill
Quote from: acousticphd on February 07, 2011, 02:41:04 PM
+1
I'd pass on this one as well.  It's not a good sign that it has neck issues and most likely has been improperly stored since it is being sold without its original case.  To me I find it odd that the factory case is missing.  Are you sure it wasn't stolen?  I wouldn't go for it especially at that price.
