Tusq pins ever stock on a Larrivee?
Started by Bltprf502, May 28, 2010, 08:10:41 AM
Does anyone know for sure if Tusq pins were ever stock on Larrivees in the 90's or anytime?  I know they have been using plastic and ebony with perspective models, but wasn't sure if Jean ever did put Tusq pins on at the factory with any of them.... Randy R do you know?  Anyone?  Just curious...
A bunch of great guitars I don't deserve and a gaggle of fly rods.... Aint life grand?
All the Larrivees I owned until the FIII arrived came with plastic pins...the FIV has Tusq I think but then I have yet to change the strings on it..
Quote from: Bltprf502 on May 28, 2010, 08:10:41 AM
 I know they have been using plastic............ but wasn't sure if Jean ever did put Tusq pins on at the factory with any of them....
Tusq pins are plastic.
Yes, they are a form of plastic... But there is a difference in a $3 set of the stock cheap plastic pins and a $30 set of Graphtech Tusq pins.
Quote from: Bltprf502 on May 28, 2010, 09:43:46 AM
Yes, they are a form of plastic... But there is a different in a $3 set of the stock cheap plastic pins and a $30 set of Graphtech Tusq pins.
Yeah, about 27 bucks worth of "difference."
Right.. :roll
Guess I'm in the minority here, but I generally like Tusq. Its consistent, which bone isn't.
Plastic has a bad reputation, and its easy to call every synthetic plastic, but Tusq claims to be 'engineered' to have the tonal properties of ivory, which is what many high end guitars used to use.
I like the Tusq myself... Its good in some guitars maybe better in others.  My new "beater" road warrior C-03 has the original Tusq nut (I think anyway), new Tusq saddle, and the pins are Tusq too... I can tell by the old drop test on the desk.  Sounds like glass or bone when it hits.  Anyway, the combo is really good!  This is the best sounding Larrivee I have owned out of I don't know how many.  Mostly because its heavy play time.  The Tusq stuff has helped this set up..  I just wondered if the pins were OEM... Probably not, but I didn't know for sure.  Thanks for posting Randy_R.
Quote from: Randy_R on May 28, 2010, 11:48:46 AM
Randy, I'm not saying that Tusq doesn't sound better in some guitars than bone or other materials. That whole can of worms is just too subjective. I have actually heard guitars that it did sound better on in my friends shop. I have watched someone sit and listen to a guitar that the Tusq did sound better in switching back and forth between saddles and he still preferred the bone. So maybe my friend and  I heard the Tusq as better and the owner heard the bone as better. Since it was his guitar out the door it went with bone saddle in the slot and Tusq in the case. Some guitars and guitar players prefer bone, plastic, ivory, wood,  or brass for sure. I'm just saying it is plastic nonetheless.
As for the claims of being engineered to have the tonal properties of Ivory, just so much marketing. I get about 20 emails a day from companies claiming to have engineered superior products to make my manhood longer and thicker, or to loose weight without eating less and exercising more, or to help me not be bald anymore. I give about as much credence to those claims as I do to Graphtech's claims about Tusq being equal to or better than ivory!
I kept the Tusq in my C-03 because I think it is more consistent than natural materials and as I mentioned it sound awesome the way it is. I think they work well with UST pick-ups which is what I have in mine.  I have tried the Tusq nut, saddle and pin combo in other guitars and it was just too brittle for me.  For some reason on this throaty well played in guitar... it is the ticket!
I've got Tusq in my L-03 and bone in my other 2 (higher priced) guitars. I've resisted changing to bone because the sound quality, to me, is equivalent! I don't have any desire to put my 'expensive' guitars to shame.
f
Larrivee L-03 w/Gotoh 381 tuners (African Mahogany/Sitka)
Collings OM2Hc (EIR/Sitka)
Schenk Ophirio (Sapele/Cedar)
Bourgeois 00 Custom (Mahogany/It. Spruce)
I don't believe that Larrivee has used Tusq pins.Mostly standard plastic or ebony.I have used Tusq myself on some of my Larrivee's and have installed lots on clients guitars with great results.I do like them over standard plastic one's as they do wear better.As for bone{ivory} I can't much of a difference but thats me.
ALL of my other acoustics have bone... This is the only one with the "PLASTIC" materials in it.  :bgrin:
I found bone pins on a Larrivee made it sound too bright, even on a rosewood dread. I've put ebony pins on my two Larrivees. Anyone know a good material for a saddle that deepens, rather than brightens the sound? Anyone make an ebony saddle?
One of the fossilized natural material items should help with that...  It has seemed to take the edge off of mine a little when I have used it.
I'm fairly certain my D-03FM came with tusq in it.
Larrivee D-03FM
1970's Norman ST68
All of my Larrivees have come with cheap plastic (black or white) bridgepins, with the exception of the Forum-III which came with some sort of hard plastic (Tusq?)
Regardless, I changed out the F-III pins to Boxwood.  Got those  from LMII;  all wood pins sound the same to me and the boxwood w/ ebony dot matches the maple binding very nicely.
Edit to add Pic of my F-III with the Boxwood w/ Ebony Dot.
(go ahead tell me these don't look awesome)
I like the plastic pins in some of my guitars.  That's whats in the P-03 I have and I tried everything!  My Martin's have always had the plastic.
Quote from: AZLiberty on May 28, 2010, 04:56:38 PM
They don't look awesome.  You asked to tell you.
Actually, I really like the look.  Do you have the LMII part # handy?  Is it the PI18K
Quote from: Mr_LV19E on June 03, 2010, 11:54:23 AM
PI18K is the correct #
