Parlors and intonation?
Started by iDavid, August 15, 2009, 06:47:07 PM
Since the Larrivee Parlor is a shorter scale does it have any issues with intonation?
peace,
david
Larrivee Forum-III all hog
Gday David,
The two Parlors Ive played didnt have any intonation issues as far as I could tell, and well they shouldnt coming from a manufacturer with the standing that Larrivee has.
I think if there were any slight intonation problems it could be sorted out with a compensated saddle.
Cheers, Scott.
Martin 000-18GE.
Martin 000-28VS
National Style O
Victoria, Australia.
No problem with my parlor either.
A couple of my guitars misbehave occasionally in the summertime but this year has been unusually easy on the humidity issues.
No problem, infact I love it
cheers
fongie
I just tested mine, and even with the compensated saddle, it does run a bit sharp on the 2nd string virtually all the way up the neck.
It doesn't bother me, though.   Part of the parlor tonal character.   I'm currently using light strings -- I wonder if mediums would change the intonation.
Gits: 2004 P-01K, 2005 OM-03MT
Uke: Kala KA-ASKS with Larrivee Flamed Koa
Chops: fingerstyle noob
No trouble with mine, a maple version of the parlor.  I rarely get above the 5th fret, however.
Greg
Quote from: iDavid on August 15, 2009, 06:47:07 PM
Shorter scale shouldn't affect intonation on any guitar. Les Pauls are shorter scale than Strats and old Supro guitars are shorter than Les Pauls, but they can all be intonated properly. As was mentioned, compensations on the saddle can be a factor. Adjusting your neck can also help if intonation is out. In humid weather a neck may bow more than usual, raising the action and affecting intonation. In dry weather it tends to go the other way... with the string action getting lower and buzzes starting to happen. I had no problem with my Larrivee parlour's intonation at all.   :thumb
dg
Intonation and scale length are completely separate items. Intonation is essentially the length of the string from the nut to the saddle, as it relates to the spacing of the frets. Tweaking the intonation is the process of adjusting that dimension by carefully adjusting the breaking point of the string on the saddle. The guitars leave the factory with very good intonation -
Tad
My understanding is that few guitars have perfect intonation, that the 2nd string tends to be off the most, and that the shorter the scale, the less perfect the intonation.
Anyway, my electronic tuner thinks my parlor has less-than-perfect intonation.   Do you guys really have perfect intonation all the way up the scale?
Actually, no guitar has "perfect" intonation. There are a variety of intonation options available, but the "standard" intonation is a balance that allows for playing in standard tuning in most all keys.
What you see on your electronic tuner has alot to do with the quality of your tuner. There is a certain margin of error allowed in most "inexpensive" tuners, and the overtones can affect alot of them negatively. Some strobe based tuners and some fancier electronic tuners can overcome those issues, but they seem to start around $130, and go up to thousands -
The simplest check for intonation is to compare the octave with the 12th fret harmonic. The harmonic divides the string exactly in half, which should be identical to the octave. Frequently it is a bit off - which may have to do with the strings, nut, neck relief, or build issue. The only ones you can fix easily are strings and saddle compensation.
Don't remember who on the Forum posted it - but this article is great - http://www.guyguitars.com/eng/handbook/Tuning/temperament.html
Its fascinating stuff -
Tad
Quote from: tadol on August 16, 2009, 05:15:05 PMThe simplest check for intonation is to compare the octave with the 12th fret harmonic.
My noobishness is in full bloom.   I can produce a 12th fret harmonic, but I don't know what it means to "compare the octave."
If I compare the 12th-fret harmonic to the fretted note at the 12th fret, my tuner shows that the fretted note is a bit sharp relative to the harmonic.
If the fretted note is a bit sharp, then the distance from the 12th fret to the saddle is a tiny bit less than half the length of the string. It's probably different on each string. If the break angle on the saddle is closer to the fretboard than to the butt, then a tech can move the break angle farther back on the saddle, essentially lengthening the string. Keep in mind that the harmonic will change a bit as well, but only half of what the fretted note will. Fitting and intonating a saddle can take some time, and you really need a very accurate tuner, since it can be very hard to hear the differences - but thats why most of the time a standard saddle is quite close enough.
But you need to read about intonation and temperament - its not as "mathematical" as I may make it sound. You can take your guitar to a good tech and have them make a custom saddle that could tweak it much closer. You may also want to read about the Buzz Feiten system -
Tad
