New Larrivee D03,slight problem?
Started by DaveyO, August 29, 2009, 07:06:43 PM
After going thru way too many guitars and too much gas, I have decided to stick with Larrivee.
I owned Martins, guild(nice and still in family) Taylors,and tried so many others,
I originally had a D05 and sold that to try something different, turns out Larrys are my favorite,suprise huh?
Anyways, I just picked it up from Sam ash for a good price,(mgrs special) and I was putting on a new set of Elixers,
I noticed that when I put the strings in the bridge , I had to hold each pin down to secure each string.
I cant remember when I didnt just put the string in withthe pin and it stood in by itself.
no biggie if the strings stay in, but is this ok, or normal?
other than that ,all is good,
anyone else have this problem, do I need fatter pins?
Dave
I wouldn't say that it was abnormal and certainly is ok as far as I know.   I've had this situation with lots of guitars and now I'm just in the habit of "seating" the ball end of the string under the pin by giving it a sharp tug upwards while I hold the pin in place.   Since I've used this method I've never had a pin work it's way out or get loose.
Its totally normal and this occurs because the ball at the end of the string hooks under the tip of the bridge pins and pushes it up.  As Tuffy said, if you bend the end of the string first, put the sting and pin in and then pull up on the string while holding down the pin, it doesn't happen.
Relax and enjoy.
Jordan.
LS-03MTHB Forum III (#19), RS-2 Sunburst
thanks so much,good to be a Larry owner again,
Do3r is next
Dave
