Backstrip / brace question...Jean`s answer.
Started by petesmithguitarist, August 16, 2009, 10:12:59 AM
Hi Guys, I asked Jean about the backstrip question as to why some guitars have it and some don`t, here`s what he said:
....the back strip means nothing, we decided to do a reissue guitar and we like the looks of it so we continued to use the strip, it is only for looks. it has no function at all....
So there you have it, from the man himself! Cheers, Pete.
Pete Smith
www.petesmithguitarist.com
UK Clinician for Larrivee Guitars
Acoustic Guitar Clinician / Product Specialist for Sound Technology Plc
Pete--
I thought you were the Larrivee Liason for the UK only, but here on the forum you're resolving isues worldwide with the tap of your keys and the click of your mouse.  If you keep this up, Super Heroes' powers will pale by comparison!  Thank you for all your help.
           DAVE
-Larrivee LSV11e (sadly sold))
-Lowden S10c
-Taylor 455ce L7
-Guild D40 (donated to science due to terminal      Onthevergeofimplosionitis)
-Brian Fry Custim 000 in the works
It helps keep the center seam together. It's added insurance and if the back has a decorative center strip outside that has been sandwiched (as opposed to inlayed) then it's necessary.
Edit: I see the 40th anniversary guitar has a decorative inlay strip unlike anything else in the catalog. I imagine Larrivee doesn't inlay this strip and that's probably the real reason it has the center joint reinforcement strip.
Hi Dave, I am indeed the UK clincian for Larrivee but Jean and I are good friends and I`m contact with him on a daily basis, if I need to know anything I ask him....thats what friends are for!
Jeremy also has a point, here`s what Jean said about that: ."..if you use a decorative piece in between the rosewood then you would need it because that decorative strip is weak made of soft wood and thats why it is used otherwise it is not needed."
The whole point of a "clinican" is to impart and share knowledge in his subject, my subject is acoustic guitars, I was Taylor clinician here for a few years before teaming up with Jean, I get asked alot about comparisons between Taylor and Larrivee and having worked for both Bob T and now Jean I like to think I`m equipped to answer with the facts when asked....incidently all my guitars  are Larrivee`s  :bgrin:
Pete Smith
Thanks for the getting the information.   I expected that to be the answer after I realized that Larrivee is one of the only guitar builders that sells almost no guitars with a center decorative strip on the back.   Unusual on the more expensive guitars, but I have read that Jean Larrivee marches to his own beat ignoring what the "industry" says should be done.
One questions does your guitar have a decorative strip or did you just get the center brace because you have a "special" OMV?
My guitar has no decorative strip between the two piece back and I didn`t specify the back brace, Jean just decided to do it that way because he " liked the way it looked".
He does things his way, not to be different but because he believes that he has found the best way to do things, I remember asking him why he made his necks one-piece when it is more cost effective to use a stacked heel block and scarf joint, his answer was..."because that`s the way I think it should be done"! .....and who am I to argue??????? Pete
Pete Smith
