Traditional series?
Started by BenF, August 03, 2009, 11:12:53 AM
Quote from: BluesMan1 on August 04, 2009, 08:13:50 PM
    Listen & let me know if you can hear me playing it! It's so loud, you probably could.
So that's what I heard from the west last night, I thought it was thunder. We normally get thunderstorms from October in South Africa... :winkin:
Hate to boast (not true) but I must have the best-looking Larrivee around. It's got the typically exquisite top, back and side woods (some would argue higher grade, since it's a higher-level model, but I've found this to be the case on the two 03 models I've owned as well). It's got Larrivee's old classical rosette around the Clarence White-Tony Rice enlarged soundhole, and now it's got the current Larrivee pickguard as well. I'm not a bling fan, so the understated silver inlay makes the perfect headstock. A lot of the guitars from this early bluegrass series had some really elaborate inlay which pleases many, but not me.  Doesn't sound too bad, either (except for my playing). Although it's a D-50, it's probably closer to today's D-60, since it's rosewood. Since these photos were taken, I've added Gotoh 510s as well. Great touches from past and present, plus it's left-handed and has a neck that seems like it was custom-made for my clumsy hands; I will never give up this guitar.
http://s728.photobucket.com/albums/ww289/leftync_photos/Larrivee%20D-50/
   LS, nice guitar, but there ARE a few things that just make the SD's special: the 12 to the body, slot-head (does make a difference like the OOO-15 & -15s), & larger sound hole. Comparing these SD-50's is a subjective thing, but as you can tell, all agree that there's just something special about them. No, they're not braced like a Martin. Doesn't matter, as they have a sound to themselves. Big difference with the 12 to the body over the 14 ones. And it's a slope-shouldered dread, yours being a square one. Does something to the sound?. When I played one of the LS-03 HB Limiteds, I immediately noticed the difference with the 14 fret neck. But it was something I found nice sounding, but not better than my F-III. So by doing an actual A/B comparison with the necks, I could tell a difference. Some nice pics on your photobucket account. Like the Martin also. And on my pics, notice the one spot of "bear-claw"? Interesting.
  And Zohn, if you could hear it, speaks volumes about the guitar, yes? :thumb
    Jeff   :guitar
  Here's a pic(s) of my SD-50. It was actually started in Jan. of '04, the neck shelved by Matthew until he had time to do the volute (he & Jean only do those), & was finished in March of '05. Almost makes it an '04, if he kept working on it! This is a common practice with him, just prioritizing his work.
'11 Martin OM18V Engelmann Custom
'11 Martin D-18 Adirondack Custom
'12 Martin MFG OM-35 Custom
'07 Larrivee OOO-60(Trinity Guitars)
'13 Larrivee OM-03 "Exotic"RW Custom(Oxnard C.S.)
'10 L.Canteri OO1JP Custom(IS/IT.WALNUT)
So it seems I have come to doubt, all that I once held as true
The Larivee site states that  the traditional om-50 and om-60 are setup for medium gauge strings.  Would the the tops (bracing) be a little too stiff, or maybe not as sensitive for fingerstyle?
setup and bracing are two different things.
All Larrivees are built to withstand the tension of medium gauge stings at concert pitch (except 12-stringed guitars).
The typical setup involves adjusting the saddle and trussrod primarily, and sometimes the nut.
A guitar is set up to play comfortably as defined by the player, without buzzing. The action may vary depending on what style the player employs. And if the player typically uses light strings with lower tension, this is a slightly different setup than if the player prefers medium strings in order to achieve the same action.
I haven't looked for a while but as I recall they used to state that the parlor was also set up for mediums, which I believe to be primarily a fingerstyle guitar, although certainly others will take exception to me saying so.
edit:
and let me say, Welcome to you labfour. Just noticed that was your first post. Thanks for joining us.
   labfour, forgot to welcome you also. Stay here & enjoy the conversations, friendship, and knowledge you can gain from others! Just can't learn enough about guitars! :welcome:
     Jeff   :guitar
Thanks for the warm welcome.   I've been contemplating the purchase of a OM50 sunburst and I play probably 80 percent fingerstyle (no fingerpicks).  But I'm still a little puzzled.  I realize the difference between setup and bracing, I used the word "setup for medium gauge strings" because thats the way larrivee  uses the term in their descriptions of their guitar specs.  If  you put light gauge strings on a guitar  (specifically OMs) setup for mediums you will  not get the same sonic properties  (especially volume) that you would get if you had a guitar "setup for lights" such the OM3  thru 0M10 series.   I 've always thought the one of the main reasons people purchased custom  and high end guitars was that the bracing was "just as strong as needed" and nothing more' you want a top that vibrates freely. Where mass produced guitars are usually overbraced to minimize the breakage and return factor.
Aside from all that, what is the boards opinion of om50 or om60 for fingerstyle.
Quote from: labfour on August 08, 2009, 05:18:57 PM
You can always set up the OM-50 with light gauge strings.
That's right and that's what enables Larrivee to put either medium or light gauge strings on their guitars.
Hey folks. I noticed my height, shape, and size of the bracing on my D-60 MR looked different than those on a Larrivee 03 series. The symmetrical pattern however, seems to be very similar. I haven't been able to directly compare to a 05, 09, or 10 series to see if this is just the difference between California and Vancouver workshops or if it is specific to the model. I also haven't taken the caliper to these things so it's an entirely subjective observation.
Does anyone know if the bracing has been CNC'ed (or even shaved) differently on regular Traditional Series or Custom Tradational Series (like mine)?
Cheers,
Adam
Lots of acoustics and One Happy Dog
"The noble savage never existed; Eden occupied was a slaughterhouse; Paradise found is paradise lost." - E. O. Wilson
Quote from: Queequeg on August 05, 2009, 12:26:32 PM
....which I believe to be primarily a fingerstyle guitar, although certainly others will take exception to me saying so.
edit:
Yes, and don't you dare call L-bodies SJ's  :winkin:
Adam - the bracing is not done by CNC at all. The material is split, gang-sawed, shaped, and glued down, all in very traditional cabinetshop methods. The pattern of the bracing is pretty standard, but slightly altered by model. The actual braces are amazingly similar, based on looking inside my few guitars. I'd have to pull strings and caliper, but looking carefully at the Forum 3 and the baritone, the back braces dimensions look identical. The top braces are very similar in dimension, but the ones I can see are shaved differently. That could be the difference between one craftsperson and another.  I'll have to start paying more attention to the interiors when I change strings -
Tad
I believe I remember seeing  a very few large soundhole L-50/60s that were done in the early 90's when the first round of 'traditional' style Larrivees were made.
I was going to add my 10 cents worth but Jeremy has it all covered, Pete  :+1:
Pete Smith
www.petesmithguitarist.com
UK Clinician for Larrivee Guitars
Acoustic Guitar Clinician / Product Specialist for Sound Technology Plc
