Tuner button size ?
Started by Daysailer, March 28, 2009, 12:53:19 AM
Does anyone know if the tuner buttons on the standard Pings have the same shaft hole shape and size as the Ping Mini's?
IE can you put a mini button on a standard Ping, or verse visa?
I once found aftermarket ivoriod buttons for my OM Blackwood at Crazyparts that worked nicely on the stock Pings. They went with the guitar when it sold. I am thinking about trying to find ivoriod buttons for my incoming F-III and the Ping mini tuners that will be on it.  After a quick check, it looks like those buttons can still be found, if they will fit the Mini's.
http://www.crazyparts.de/mode/tunerbuttons/000000948a09cb01f.php   (the buttons I bought from my OM)
tks...ds
L-03 BlackWood..... "Pluck"
OM-03- MT Forum #14/17
F-III IS/Hog #63/78....SOLD
Seagull Artist Folk
Pono and Kanile'a Tenor Ukulele's
The real Day Sailer...1966 Day Sailer..the boat, not the person
As long as the button fite on the shaft should be no problem....well maybe a little on,you might have to get a longer screw.
That was my question....
Is the shaft hole the same shape and size,  less length, on the standard and mini Pings?
Seagull Artist Folk
They should be.
DS, your problem is that the mini pings have a spring inside them, rather than on the shaft before the button.  Therefore, std buttons may not fit.  Here is an ivoroid tuner button that has the same fitting as the ones I have on my OM-03 with std pings.  Mine are shown below, but they are the larger button.  You will notice that the screw doesn't sit properly.  The manufacturer who took the picture says they will work fine, it is just a look thing.  Check out Michael T's thread in the technical section on Ping tuner buttons for detailed descriptions.
The seller is Rothesay Music in Scotland, and they ship worldwide.  Photos don't do them justice, they are superb.
http://stores.shop.ebay.co.uk/rothesay-music__W0QQ_nkwZtunerQ20buttonsQQ_armrsZ1QQ_fromZQQ_sasiZ1
Ben
2009 FIII LS-03RHB #5
http://www.youtube.com/user/1978BenF
Ben, thanks for your response and Pictures.
You can see the ivoriod buttons that I put on my OM Blackwood, in this thread where that guitar was recently resold.
http://www.larriveeforum.com/smf/index.php?topic=25181.0
Changing the heavy chrome buttons for these lighter ones really made a difference in neck and guitar balance on my knee.
These are the ones from the Crazyparts site.  I prefer the Grover shape to the more squared Ping/Schaller shape. Quality was also first rate.  I'm just hoping I can get these buttons to fit the mini shaft.  If they fit,  it would be easy to reshape them smaller and repolish if I find they look too large.
Seagull Artist Folk
Quote from: Daysailer on March 28, 2009, 05:01:06 PM
They may well fit, they may just need the screw carefully countersunk.  I am not sure how easy this would be with he ivoroid material without it splitting.  I am not much of a DIY kind of guy (I try, but I tend to break more things than I mend).
As I have said to someone else, if you hang fire the I will try my ivoroid buttons from my OM-03 on the forum III when it eventually gets here, and post pics.
Ben
Ben
Tks, Ben
I was hoping someone could try a stock Ping button on a mini shaft to prove the size and shape fit.  The screw length should not be a huge problem to solve.   Carving the plastic (ivoriod) and getting the outside shape modified will be easy.
Shifting back into wait'n mode..... :beer
Seagull Artist Folk
Quote from: Daysailer on March 28, 2009, 06:03:34 PM
Tks, Ben
They definitely fit, I have the larger ping buttons on my F-III right now, I might just order some of these also, thanks for the tip.
danny
Thanks, Danny.  Knowing 'absolutely for sure', makes ordering from Germany a bit easier. I really liked the Ivororid button with the Ivoriod fingerboard binding, and maple body binding.  Light colored vintage bone bridge pins finished the look off very nicely. I'm thinking the extra light color of the IS may also add to this overall picture.
Tks for all your posts and Pics of your F-III.  Helps keep the spark alive....ds     :beer
Seagull Artist Folk
Quote from: Daysailer on March 28, 2009, 06:33:13 PM
I think you are right about the ivory color tuners on the IS etc,
And all my posts are just because I really do feel the way I do about this F-III... it met and exceeded all my expectations. I truly hope all others feel the same about theirs when they get them.
danny
