fisherman acoustic aura pedals
Started by garyjordan, March 23, 2009, 10:01:11 PM
I am interested in picking up one of the fisherman aura pedals and have a LV=03.  The pedals are matched up to 6 typical body styles; dreadnought,orchestra, concert, 12 string, nylon string, and jumbo.  I'm thinking that the jumbo aura would be the best match to the LV, but, want to double check with others.  Thanks!
The body dimensions would be closer to a dread than a jumbo if that's any indicator.  Are you able to try both pedals before you buy to see what works best?   What sort of preamp/ pickup combination are you using with your LV?
I just bought a slightly used Aura dread pedal to experiment with.  I have two OM's with passive UST's  and a Larrivee dread with a basic fishman UST and preamp on board.  I plug these into a Radial PZ pre, and then into the Aura pedal and finally into a Genz Benz amp which is set flat.   Four or five of the aura settings work pretty well.   I mix the Aura about 25% or less with the original signal to add a bit of mic like sound to the mix.
Thank you for your response.  Right now, I am going straight from my LV with the stock b-band system into my traynor acoustic amp.  What I am trying to get is more of that mic'd  sound quality.  Tell me more about using a DI in front of a aura pedal.  I don't think that I understand what that would do exactly.  THANKS AGAIN!!
p.s.  I was going to order the pedal on-line, but, sounds like it would be smarter to go into town and try the aura pedals out.
