Carnauba or Not?
Started by makanani1, December 03, 2008, 01:59:55 PM
Turtle Wax Express Shine- this product has been recommended and used by many high end guitar luthiers. Does anyone use this or similar products (Meguiar's Carnauba wax) on their Larrivee's?
Any advise is appreciated, don't want to harm my LSV11e in the long run
Taylor T5 Custom Koa
Taylor 814ce
Taylor 614ce
Alvarez MD350
I use a hign end furniture wax on my guitars. It isn't really necessary, but I like to rub them and buff them out and admire the wood. Carnuba wax is extremely hard and takes a bit of effort to buff out - great for floors and other high wear surfaces. Your guitar does not need that kind of protection.
Don't know the Turtle wax product, but alot of the car waxes are high in silicones. I try to avoid them. All wax really does is offer a wear surface to minimixe the wear on the actual finish.
If you just wipe it down with a clean soft cloth every time you play, you can avoid alot of these chemicals -
Tad
Quote from: makanani1 on December 03, 2008, 01:59:55 PM
You should have a microfiber cloth that was included with your LSV, that is really all you need.
         If it ever gets pizza grease on it  :ohmy:, you could use a small amount of Murphy's oil soap in water and wipe it off. Then just keep the micro-cloth free of any debri that might scratch the finish. Diapers are good for the murhy's and water. Keep the wet stuff away from the fretboard and the soundhole though.
                     Where did you purchase your LSV-11E? I just sold mine due to shoulder issues, but I really like the LSV's.
Welcome to the forum, makanani1; I also have an LSV11e and usually just wipe it down with a clean cotton cloth, but will occasionally apply to  the finished surfaces  Smith Pro Formula Polish or Martin Guitar Polish.
          DAVE
-Larrivee LSV11e (sadly sold))
-Lowden S10c
-Taylor 455ce L7
-Guild D40 (donated to science due to terminal      Onthevergeofimplosionitis)
-Brian Fry Custim 000 in the works
Larrivee uses a UV cured polyester resin finish on their instruments. Really tough stuff, crystal clear. The premium grade granite slabs our company imports uses that finish on them just as an example. There is no need to apply waxes or other products that may leave a chemical residue or build up. For cleaning, small scratch or swirl removal, and a haze removing polish occasionally treat it like a clear plastic (think polycarbonate lenses in glasses, or convertible rear windows). I use the Meguiar's pro mirror glaze products once in a while. Theres a detailer for frequent cleaning (#18), a cleaner/swirl remover (#17), and a polish (#10) that leave no residue and are anti static & easy to use (designed for plastic windows). Unfortunately they aren't found in stores, maybe detail shops or body shops. I order mine from their site.
http://www.meguiars.com/estore/product_list.cfm?sectionname=Professional%20(Mirror%20Glaze%20Brand)>Clear%20Plastic%20Care&sectionID=34101
08 Larrivee L05-12
02 Larrivee DV-09
73 Granada Custom
Kids got the others  :)
Quote from: Michael T on December 04, 2008, 07:27:57 AM
Michael, the more I learn about the UV polyester the more I see that it is a "plastic encasement" so this is the right track. #1 don't use any thing. #2 what you have described above. I have been using many different Meguires products on cheaper guitars and for a small area in need of polish on the better ones. Some success and some failure. But not much is available on the UV cured stuff, other than be careful not to scratch it.
really? Acoustic luthiers? (or just for electric guitars?)
Who?
A water-dampened cloth is all that is necessary. Gooey stuff can be removed with naphtha (lighter fluid).
That is all. :cop:
You want to be very careful about applying chemicals to the finish of your guitar. Remember there a number of different finishes that guitar makers use (polyester, lacquers, French Polish) and they will react differently when you apply waxes, silicons, cleaners, etc.
If you use any type of auto products, make sure it says somewheres on the label "Body Shop Safe."  That usually means no silicone.
http://community.webshots.com/user/fng45
Life is too short to drink cheap beer.
As previously stated avoid silicones!
I use pure carnuba on the neck, it is very hard and keeps my hand sliding easily.
I have also used the carnuba on the top in places where I might leave an errant strum mark.
I usually wax the area between the pick guard and the shoulder on the upper bout.
You can find pure carnuba at a good woodworking shop.
My luthier recommended the carnuba and warned me NOT to use an automotive product.
SD-60 SBT
O-50 TSB
OM-03 Koa
D-09 12 string
Gibson-J50
Gibson Blues King
A gaggle of ukes
Make sure that whatever wax you use contains no silicone.Not good for guitar finishes. DougS
Quote from: dependan on December 03, 2008, 10:33:39 PM
Danny, Thank for your input. I purchased the LSV11e at the Dallas guitar show last year. It's been my favorite ever since.
Also have Alvarez MD350, T5 Custom Koa, Taylor 614
Taylor 814ce
Taylor 614ce
Alvarez MD350
Most any wax will work provided it contains no silicone. Silicone can cause future problems should you ever wish to re-finish your guitar
