LR Baggs Notch
Started by Z88, December 03, 2008, 03:48:49 PM
I currently own an LV-03R with the LR Baggs Notch system. For some reason when I play through a PA, it sounds like my high E and B are the only strings cutting through the mix and the other four strings don't. I only have this problem when I am doing lead work.
Also, I feel like I have to crank the volume in order to get a great sound out of the preamp when doing rhythm work.
I've been frustrated with these problems and want to know how to fix them
Is this an issue with the LR Baggs system, or something other?
Feedback please!!!
Make sure that your bridge is perfectly flat with a slight lean toward the sound hole. Take it out and place it on a known flat surface like a mirror. If it is not perfectly flat, place some sand paper on a known flat surface and lightly sand until it is.DougS
