Got my OMV-03R =] Question though
Started by mmmyom, September 04, 2008, 01:19:25 AM
I got my OMV-03R today (super excited  :bgrin:)
Phew, what a relief.  I went through all the troubles worrying about whether it had any cracks or anything extreme, and now the time has come (UPS truck), and it is great!  It looks great, at least, besides some dings here and there. =]
I haven't played it yet, but only because I can't string it!  The pegs keeps popping out when I tighten the strings, and I think it's because the pegs are old/bad.  So this is my question.  The guitar is, pretty old, so I was wondering if I should purchase some new pegs and maybe a new bridge.  And if so, what could I request at GC (Guitar Center)?  Btw, I don't want to spend top dollarz.  :tongue:
Also, the square transparent pickguard picked up some ugly dirt/dust/idontevenknow, so I'll be replacing it with a new one at GC.  Should I ask them for the normal Larrivee pickguard?
Pictures will be up soon, thanks everyone  :donut :donut2 :coffee Got Doh-nuts?
mmmyom
This question pops up from time to time here.  Usually it's a matter of making sure you are seating the ball end of the string properly under the pin.  Certainly a  new bridge would be a drastic remedy which I don't believe you need at all.  First, make sure that when you insert the ball end into the hole that you insert far enough and when you push in the pin hold it down while you give a couple of sharp tugs on the string straight up.   That should seat everything pretty well.  Then to be safe, hold the pin in place as you bring the string to tension with the tuning machine. If it's seated properly you shouldn't have any problem with the pins popping up.  If you still have a problem you may need to get yourself a new set of pins that will work better.  I'd take it to a tech at that point to make sure of a good fit and watch him install a new set of strings just to make sure your technique is correct.   You need to get some stings on that thing and get busy with it.
Good Luck
tuffythepug
Since I'm experiencing the same (on a relatively new OMV-03), I'm glad to read your comment Tuffythepug. Thanks for the clear description, it's confirming the technique I discovered myself  :winkin:
Thanks for the help tuffy, I'll try it right now =]  Hopefully the string doesn't snap on me again =/
Thanks, I'm loving the condition/appearance =]
Also, would employing a capo reduce tension?  I tried Tuffy's method, and the peg sat in its spot properly, but when I reached around D (on the E string), the string snapped on me, again.
