Pick-Up for OM
Started by Folkestone, July 21, 2008, 02:43:59 PM
Hi:
I've got an OM19. I need insight on a good pick-up.  Obviously I want to make minimal mods to my guitar, but I'd like some control with a pre-amp.
I always appreciate everyone's advice or comments.
Thanks,
Jeff
K&K pure western mini and a K&K XLR preamp....AWESOME combo...great tone and no mods needed!
Blue
OM-05MT "Mary Helen"
Silvercreek T-170
Harmony Herd (1203, 162, 165, 6362)
+1 on K&K Pure Western Mini and Pure XLR preamp.  (Hi Blue!)
www.davidberchtold.com
     I have a L.R. Baggs Element Active that has a preamp and volume control that came on my Martin OM-21.
I was wondering what others thought about this type. I always hear this statement.
Quote from: dberch on July 21, 2008, 03:23:38 PM
Well I don't hear the "Hi Blue" part usually along with it,but you get my drift. Any feeling pro or con on the Baggs Element?  Danny
For under saddle pick ups, the Element is a good one. The K&K is an under bridge pick up more like the LR Baggs iBeam.
Some of these discussions are purely personal preference. I (personal preference here) like my preamp onboard, but don't like to cut up the body. So going with an active iBeam or active Element would be my choice over a K&K Pure Western with an external preamp. Less to set up, carry, and fuddle with, and if I need to make a change I can do it on the fly and don't have to walk over to a preamp. Although, I AM NOT saying they sound bad. Either the K&K or the LR Baggs units are top notch. I just like an onboard set up.
I use an iMix, which is a blending of both the Element and iBeam. Depending on the sound set up, I will sometimes substitute an non powered M-1 for the Element. Usually when there is feedback issues.
"The barrier to knowledge is the belief that you have it"
2006 Larrivee LV-10 MR   1980 Les Paul Custom Natural   2008 Larrivee LV-03-12   1998 Carvin LB75 Koa Bass
Thanks Dale, I don't gig but I do play a little at a wedding now and then and my amp has been used by others. I only use it at the house rarely, but the new to me Martin might change that a bit. Although I'd rather play the LSV but no pickup in it.
       Thanks for starting this thread Folkestone,   Danny
Just for your personal knowledge, you can take the active element out of the Martin and install it in your LSV if you wish. None of these pick up systems are designed for a specific guitar. However, some of them will be easier to install in some. For instance, the K&K mini is usually preferred over the K&K because the smaller pads fit better under the bridge of a Larrivee.
Also, K&K does make onboard preamps as well. I just noticed my last post and I think I might have made it sound like the LR Baggs was all active and the K&K was all passive. Just for clarification, both companies make passive and active systems and both companies make systems that will combine the pick up types with blenders if you desire to install a couple options and blend them for authenticity of sound reproduction.
Thanks again Dale. I think I'll leave my LSV as is. It's really "my" guitar. I'll have a 00-50 or a LS maple or something else some day. Or who knows the OM Martin may grow on me. My old Gibson has a pick up also, couldn't say what kind. I have never plugged it in.   Danny
k&k western mini sounds very very good... if you have trained and expert hears... than add the preamp (XLR, or the beltclip one) otherwise with a good amp even the simple passive pickups are enough!!!
