Sharp fret ends on D-03
Started by manfredh, June 05, 2008, 12:04:38 PM
Hello there,
I have been lurking in the wings of this forum for a couple of months.
My name is Manfred and I live in Germany, and I'am not a guitar expert.
On and off I have been dabbling on the guitar for many years.
A few months ago I went to a music store to buy a new guitar. I had never heard of Larrivèe before and had actually wanted to buy a Yamaha.
After trying out several lower-end guitars from 500 to 800 euros, the knowledgeable salesman fortunately gave me the D-03 and it blew me away and I went back and bought it the next day.
My wife had not wanted me to buy a new instrument. But when she heard my modest finger-picking on the D-03 she could not but remark: 'now this guitar has a very nice sound'.
I am really happy about my purchase and have started to practice seriously again.
My question for you Larri experts is the following:
I have noticed that the fret ends are a little sharp, especially on the higher E side, which sometimes interferes with my sliding up and down the neck
I don't think that this is a lack of humidity problem, because we have plenty of humidity in Central Europe and I also have a weather station that shows humidity levels.
Do you guys use any tricks to smooth such fret ends?
Thanks for any comments
Manfred
Bring it to a tech and have him dress the fret ends.
Yeah . I wish larrivee would do something about this , on an otherwise perfect instrument. Compared with my other guitars of different brands, Larrivee does have very sharp fret edges that is kinda annoying when sliding up and down the neck. It actually hurts the inside of my hands.So I hear this can be improved or totally eliminated if brought to a tech? It looks like the ivoroid binding would be affected since the frets are well buried inside the binding.
Has anyone got any experience on this ?  :?
***I stiill got so much to learn***
My son Obiwan:
http://i38.photobucket.com/albums/e130/Edwardtang/Obiwan/DSC000017157114343.jpg
Larrivee OMV-10E (Mermaid headstock inlay)
Larrivee D-60
Martin D-42K2 All Koa
Taylor JDCM All Koa
Taylor K-20-C All Koa
Taylor PG-LTD Myrtle
....and many more Electric guitars
It is a fairly easy repair to do on a guitar; bound neck or not. It should only take a qualified tech 20 to 30 minutes to do depending on the number of frets needing dressing.
Now if you're talking about the tang of the fret sticking through the fingerboard binding... that is something else altogether and it usually caused by low humidity when the fretboard shrinks and the fret tangs protrude through the binding.
2016 Martin 000-28vs 12 fret
2014 Taylor 814ce
2014 Godin Multiac Classical
2012 Gibson "The Golden Age 1930's" SJ200
2012 Squier Vintage Modified 70's Jazz Bass
2010 Gretsch Electromatic G5122DC
2009 Taylor GA3-12e
2004 Fender American Deluxe Stratocaster
1981 Rickenbacker 320JG
1968 Yamaha FG150 Red La
I would just take a littel sandpaper and go to it.
I had the same problem with the nut, it was kinda sharp in the first position.
I sanded it down little by little , problem solved.\
hope this helps
Dave
  All of mine were sharp when I bought it, all I did was humidify it.
hmm...maybe I will try sanding it down one fret at a time . I don't think it is a humidity problem since it's quite humid here ..and nothing seems to be sticking out (frets). I've tried many Larrivees (and Morgans of similar construction) and it seems like it is designed that way...with a little sharp edged fret.
Oh , and thanks to everyone for taking the time!
My son Obiwan:
Larrivee D-60
Taylor JDCM All Koa
This is a great little tool for dressing fret ends. Just a little twist of the wrist as you go by the fret on an angle and you'll have a beautiful soft curve in no time.
StewMac
2014 Taylor 814ce
2009 Taylor GA3-12e
Take a sanding block and carefully go along the edges of the finger board. Don't worry about the ivoroid binding it will sand smoothly and Larrivee's need the binding profiled a bit from the factory hard right angle to play comfortably anyway. Just make sure you stay on  ONLY THE BINDING with the sanding block and do not let it hit the finish on the neck. If there are still sharp edges, take a fret file to the individual frets. My 000 plays much nicer for thumb wrap arounds since I profiled the binding edge and frets a bit.
 :bgrin: Thanks again for the help!  :cheers :cheers
My son Obiwan:
Larrivee D-60
Taylor JDCM All Koa
