Fretboard Extension - To shim or not to shim?
Started by pickngrin, May 15, 2008, 07:54:09 AM
I'm resetting the neck on my old Harmony and it has always had a lot of drop-off from the 14th fret to the sound hole. The will be worse after the reset is complete unless I shim it. So, is it time to shim or will it be ok to have that much drop-off and the accompanying 14th fret hump?
I don't have spruce shims so I hope my mahogany shims will work for this.
Thanks,  pickngrin     :thumb
Martin 0M-28 Marquis
Martin HD-28VS
Harmony Sovereign H1260
Larrivee Bakersfield
Taylor GS Mini
Alvarez Yairi CY130
Have you thought of trying to make a clamp jig that you could use, to slowly, over time, bring the top back into correct geometry? You might be abe to use slow tension against the top to move it your direction rather than the strings using tension to move it their direction. If you go the shim route I'd use the mahogony shims or if possible a shim of the same wood as the finger board to blend better.
