Need Help with pinless bridge saddle
Started by pickngrin, May 13, 2008, 09:15:19 PM
Does anyone know what would be a good height for the saddle on an old Sovereign with a pinless bridge, after a fresh neck reset. Is it the same as a pinned bridge with 3/16" being a good height?
Also, the saddle slot is only 3/64" deep so should the depth be lowered to accomodate a taller saddle?
Below is a pic of the bridge in question, before I removed the neck.
Any help, greatly appreciated,
pickngrin
Martin 0M-28 Marquis
Martin HD-28VS
Harmony Sovereign H1260
Larrivee Bakersfield
Taylor GS Mini
Alvarez Yairi CY130
I have an old Sovereign and I cut the slot larger to allow a Gibson style adjustable saddle. But mine is a mustache rosewood pinned type. These Harmony's didn't have the greatest saddle setup from the factory. So that's why I chose an adjustable, then I made a bone compensated saddle to fit in the slot. It worked out well for me because I just didn't want to lose that nice rosewood mustache bridge.
           Even though you have had a neck reset the Ladder bracing will allow the top to become "pregnant". If yours is a little to domed looking you may just need to fit in a saddle and see how it works and then make a new one or adjust the one you have tried at first.
           Of course I'm not a Luthier, but I do find ways to make my gits sound better or look better (most of the time)
If you can buy a pre-made compensated saddle (All Parts Tusq) they are less than $10 and you can make a trial run or two with them.                               Looks like a nice top on your Sovereign. Take what you want and throw the rest away of what I have said. Let us know how it turns out and I'm sure I'm not the only one that would like to see a full picture of you guitar.    Danny  :donut :coffee
Danny, thanks for the info. Here's a pic of the Sovereign, I removed the neck today and I'm trying to decide what saddle height would be best and if I should deepen the slot with a straight edge wrapped with sandpaper. I know it should be routed with a jig but ya gotta use what ya got.
Mustache bridge huh? We wouldn't mind seeing that one either.  :smile:
Martin HD-28VS
Taylor GS Mini
Alvarez Yairi CY130
This one is just like mine and I already have the picture on file, this one has had a much wider saddle installed.btw I use a dremel to enlarge slots, I've done O.K. so far. But I won't go near my LSV-11 with a power tool.
                          This is a Fender Sovereign, It has Fender tuners, 3 to aside and a Fender logo on the headstock which matches th screwed on pickgard.
                           Does this make it "Boutique"...just kiddin folks
It depends on the height of the bridge, normally you want about .5" between the low E string and the guitar top. I don't know anything bout that guitar though.
