Can switching to mediums help buzzing?
Started by fumblefingers, April 09, 2008, 03:21:28 PM
I bought a used 2000 D-02 about a year and a half ago.  It's my first acoustic guitar and I absolutely love it!  I really like the clear and expressive bass, exceptional tonality throughout all the strings and the action is set very low, making it quite easy to play.  It's allowed my skills to advance to the point where I've joined a 6-piece church band in which I play primarily rhythm.
Up to this point I've strung it with lights (12s), which is how it came from the guitar shop.  For as long as I can remember, though, there has always been some moderate buzzing on the low e and d strings when fretted.  I asked my guitar teacher about it, and whether he thought I needed a set-up, but he said most guitars will have some extraneous noise and this one wasn't so bad.
I was just wondering whether using mediums might help the situation.  It would seem to me that mediums are stretched a little tighter and might not vibrate as much as lights do, thereby clearing a high fret or whatever.  Taking it in for a set-up is also a possibility, but we're gigging ever Friday night through the middle of May so I'd wait until then to take it in.
One more thing.  Last time I changed strings I also changed the 9-volt battery in the Highlander undersaddle pickup, and noticed the saddle is very loose.  I mean turn-the-guitar-on-its-side-and-the-saddle-falls-out loose!  Is it supposed to be like that?  Could that be part of the buzzing problem?
I'm fairly new to this forum but I've used mediums to give a bit more relief to the neck on occaision and to help reduce buzzing. Check the neck with the current strings on it. Looking from the headstock to the body of the guitar, what does the relief look like? Is it flat or is there some slight curve. A bit of curve isn't bad. How is the saddle set up? Is the action really low or does it meet the specs for the guitar. I've had guitars that just won't stop buzzing and it's been because the bridge was too thin. Ultimately putting a really tall saddle helped although in truth the proper height bridge would have been a better but more costly solution. Also, a loose saddle isn't bad as long as it sit upright. You really don't want it to be tilted in the slot. It need to make good solid contact with the bridge at the interface of the saddle and the bridge. Also it may only need a slight truss rod adjustment to eliminate the problem. The result from looking at the curve in the neck will tell you that. If none of this makes sense then try bringing it in to a luthier and see what they say.
-Lee
(Bend, OR)
Welcome fumblefingers -
Best to select the strings you want to use and set up the guitar from there; not the other way around. Buzzing can have a multitude of different causes. LV19E  has given you some good links. Frank Ford at frets.com covers buzzing in some detail. There should be some relief in the neck. this is controlled by the truss rod. There should be enough relief in the neck so that when you hold down a string at the 1st and the 13th fret there ought to be enough room over the middle frets to slide a business card in there.
It's OK that your saddle is loose when there are no strings holding it in (as hogwldfltr says).
And your saddle should be tall enough to create a good break angle for the strings to the bridge so that the energy (sound) will be adequately transferred to your sound board (the guitar's top).
