Leveling Stainless Steel Frets
Started by pickngrin, April 09, 2008, 03:24:50 PM
I'm experimenting to see if I'm capable of installing SS frets after refretting a few guitars successfully with NS frets. I plan on using cheap tools so I can dispose of them when they get dull. I've been able to hammer in the SS frets and bevel the ends without any problem. I also leveled a few of them and although it was slow going, the mill file did the job.
Now, it's time to crown them and if anyone has experience with this, please advise me. I'm afraid to use my crowning file so I'm considering making a small hardwood sanding block with a little groove to fit over the frets. I could then start with say........ 150 or 220 grit paper and increase the grit until they are smooth enough to finish with a fine paper and my hands. I've seen this fret sanding block somewhere, maybe in Erlewine's book at the library. Is this a decent plan or do I need to go in a different direction?
I enjoy learning this stuff and will probably only replace the lower 7 frets on a couple of guitars. Any advise given will be greatly appreciated.
thanks, pickngrin
Martin 0M-28 Marquis
Martin HD-28VS
Harmony Sovereign H1260
Larrivee Bakersfield
Taylor GS Mini
Alvarez Yairi CY130
I've worked with stainless steel frets.My best advice is to buy a diamond encrusted crowning file.Check Stew Mac or Allparts,I don't remember were I got mine.
By the way I love the SS Frets do the job once then never again.
When I fretted my guitar, part of the process was to use a crowning file to dress the top of the frets.  It worked great and wasn't overly difficult.  I believe that the proper proceedure is to level the fret, finish the edges, then crown the frets and polish with a rotary tool.
Let us know how it turns out...
jimmy
