Another Word on Pins.
Started by ducktrapper, March 29, 2008, 09:32:55 AM
Just as a point of interest, I thought I'd share this. I was changing strings on my dread yesterday. Most often I change one string at a time but as an experiment I put my old tusq saddle back in as well. Anyway, I took all the strings off, stuck the pins back in, so a as not to misplace them, and began with the low E. I bring the string up near pitch, stretch it a couple times, repeat and then move on to the next string. That done, I picked up the new A string to put it in, reach down and promptly pulled the end pin out of the newly tightened E string. I always understood that, in theory, once the string is properly set, the pin doesn't do much of anything but I accidentally proved my point. Now there was a well set string. I've changed a awful lot of strings in 43 years but have never actually done that. Cool.
That works if the bridge is slotted but if it isn't it slotted you'll probably need the pins. The 'end pin' is the strap button on the very bottom of the guitar btw.
Oh yeah! Wanna make something out of it! I'll call potatoes if'n I want.
Thanks I don't know what I was thinking.  Doh!  :arrow
I've edited and now we'll both look eccentric.  :laughin:
Okay I've never seen a guitar that wasn't slotted for the string, btw.
Quote from: ducktrapper on March 29, 2008, 09:53:38 AM
Well most guitars have bridge pin holes but some also have slots on the saddle side just big enough for the string to fit in; more common is to put that string slot in the bridge pin. My OM-03MT wasn't slotted and I'm pretty sure the string won't stay in unless the pin is in there with it. It gets lonely. (how's that for eccentric  :doh )
Well I was hoping to find some info on "end pins''; but I did get some good humor.  :arrow Danny
Talk about senior moments! Bridge pins!!! It just came to me!  :blush:
