saddle question
Started by bigjay, March 04, 2008, 12:54:37 AM
I just got my new LV-03RE and I love it .  Thing is the saddle seems kind of high . I seem to be getting a buzz from the low E when I play a G chord. But I wonder If the neck is a bit wider than on my dread that i have played for the last couple years.  Do you think  :?I should have the shop lower the saddle or do I have no idea what I am talking about.
More money than talent and I'm flat broke!
chances are very good that your dreadnought has a narrower nut width than your LV-03RE. The L has a 1 & 3/4 nut width and most dreds are 1 & 11/16ths.
You can lower the saddle if it is too high.
However neither of these conditions is likely to explain your fret buzz. If you're getting buzz @ the 3rd fret this is more likely a function of neck relief, and often a minor truss rod adjustment will remedy this situation.
visit www.frets.com for a tutorial on Buzz Diagnosis
Other frets.com subjects you will find helpful such as making a saddle, truss adjustments & checking neck angle are found here: Troubleshooting & Repair
I had the same problem and simply switched to GHS S325 strings which are still light guage but have a .054 bottom E instead of .053  the buzz is gone completely.
Sounds like you need to take it to a guitar tech. I don't suggest changing things if you don't know what's causing the buzz.
Ya I was hoping since i just bought it they would have a look at it for free . I think ....
If you bought it from a music store they should do a setup for free.
