Pickup End Pin popped out 1/2 an inch - can't get it back
Started by ST, February 18, 2008, 12:41:08 AM
I have a Larrivee Model C38 Classical - circa 1981 with an unknown under saddle pickup and end-pin jack.
Tonight I picked up the Guitar and noticed that the end-pin jack had popped out about 1/2 an inch. It is quite loose and spins freely.
There is not a nut that screws down over a hollow shaft. When it was sitting in there properly, the knurled end was nearly flush with the body of the Guitar. It could not have functioned as a pin for a strap.
I was hoping that someone can tell me or share a picture of how it is secured inside. Then I can take a shot at putting things right.
Thank you for your help.
PS
It is *not* one of these that can be screwed on from the outside.
PPS
It looks sort of like this except that the thread goes all the way to the end (left end in the picture)
PPPS
I had a friend with a tiny arm reach in there but she cannot feel any edges on the "ring" on the threads.   It's almost as though it was a pressure fit or snap ring deal because it just seems to have slid up about 1/2 an inch. There are no excessive twists in the wire that I might expect if the jack had somehow turned the many times it might have taken to loosen it this far.
I would just replace the jack with a new one, something like the one in your top picture. Then you can put a strap on if you would like to, or not.
  :coffee  :donut2
Hi Mr_LV19E,
Thanks for your reply.
Interesting idea, but at this point I cannot get the jack out either. I can't see what I am dealing with with a mirror, and the tips of my fingers are calloused enough that I can't quite tell what I am feeling. That's why I'm wondering if anyone has a picture or can tell me what is likely going on in there.
I'm just guessing but if it wont pull out it probably has a nut on the inside that is loose. If it has a shield over the solder posts like the one in your top picture and the nut has loosened up to the shield you could just tighten the nut or remove the shield and the nut and it should slide right out. Try slipping a mini mag light in through the sound hole and let it lay on the back, then take a small mirror like a compact mirror and slip that inside the hole and see if you can get a look at the tail block. If you have a small digital camera you might be able to put that through the hole and snap a picture of it. Set a piece of foam or something on the bottom the height of the braces so they don't interfere with the lens focus.
Those were great Ideas, one more would be to go to an auto parts store and buy a telescoping swivel head mirror, they come in different shapes and sizes. A larger rectangle mirror head would work well. Then you place this mirror in the sound hole and maneuver it back to the end pin. Then with another mirror like a small pocket one and a light in the sound hole you can manipulate both to see the inside of your guitar. Try shining your lite at the telescoping mirror head  and it can reflect up towards the sides of the pin and give you another angle.(I know this sounds convoluted but with a steady hand and a little patience you can at least see what the problem is.  Stew.Mac also sells an unfolding mirror that fits in the sound hole and then you open it up to get a full picture of the inside of your sound board.   Hope it works out, I would like to know how you eventually fix it. Danny
Hey everybody,
Thank you for the great advice.
Reading over these ideas I realized that there was a decent chance that I'd break something if I spent any more time poking around in there.
So I just got in touch with the folks at the shop where I'm getting an LR Baggs iMix installed in another Guitar. They said that they will take a look at this connection jack when I go to pick up the other one.
Thanks again.
I picked up the C10 BZ with the iMix No Cut installed today.  I also took my C38 Classical in with me and they had me out of there in under 10 minutes, with the pickup jack snug as a bug. The fellow who took it back to the shop said, "Sure, we have a tool for that".
