Light or Medium Strings on OM-03R?
Started by ChadHahn, April 06, 2007, 11:27:50 PM
I have a OM-03R that I have medium strings on.  It buzzes so if I stay with mediums I'll have to have the action raised.
I have a Colosi bone saddle that I'm going to have installed.  Now I'm thinking, should I stay with mediums or would the guitar sound better with the lights it came with?
Let me hear your opinions.
Thanks,
Chad
I find that lights sound better on my Martin OM. Sometimes I change the 12 & 16 to a 13 & 17 for a stronger high end.
Martin 0M-28 Marquis
Martin HD-28VS
Harmony Sovereign H1260
Larrivee Bakersfield
Taylor GS Mini
Alvarez Yairi CY130
If you're going to have your Colosi installed as part of a general setup ... which is a good idea, since you say it buzzes, and the saddle should be adjusted after the relief and nut ... you need to decide what kind of string gauge you like first.
PUtting lighter strings at the same action settings isn't going to make it buzz less.  Probably more.  LIghter strings vibrate in a wider arc and so are more prone to buzzuing than heavier ones.  I think you've had the action lowered a bit too much.
Since your guitar came with lights, do you like the way it sounds better with mediums?  No one can answer that better than yourself.  Are you a hard plectrum player?  A softer fingerstyle player?
MInd you, your particular guitar may sing better for you with lights, even if the maker says mediums are OK.  Depends on the sample sometimes.
Anyway, it sounds to me like you should experiment a wee bit with strings before the saddle is installed.  The problem with acoustics re. electrics is that an acoustic saddle is much, much easier to lower too much than to raise back up again.
I think you'll be happy with the sound afterwards though.  I have a Colosi saddle and it's the best 40 bucks (what it costs by the time you get it into Canada) I've ever spent on a guitar.
My OM-03R sounds MUCH better with mediums (I use John Pearse Medium Phosphor Bronze). I have a Colosi bone saddle and bridge pins installed and am toying with the idea of a bone nut in the near future.
Dan
"Time flies like an arrow..Fruit flies like a banana"
Townes Van Zandt
Count my vote for mediums...even though I use med/lights sets.
bluesman67
HOGTOP CHARLOTTE
I'm coming to the conclusion that guitars I don't play as often (in my case, a few inherited guitars that I'll never sell) should get lights (or even extra lights on an old Gibson) for the lower tension, while I'm really starting to like mediums or possibly med/light for daily use.
I'm a fan of lights on my OM...I tried mediums but they just sounded compressed...the thump of the bass was nice but the treble didn't sparkle like it does with lights....I think I'll try the med/lights in the future and see if thats the best of both worlds.
:cheers
Blue
OM-05MT "Mary Helen"
Silvercreek T-170
Harmony Herd (1203, 162, 165, 6362)
Chalk me down as another member of the light gauge camp. I tried mediums on my own OM-03R and didn't like the way they felt so stiff. Of course, that was before I had the guitar properly set up (for lights) and IMO I've always played with a delicate touch anyway.
Neil K
2026 (unfinished) DIY 00-18 (Sitka Spruce/S. American Mahogany)
2025 DIY 000-28V (Sitka Spruce/Black Walnut)
2023 DIY Medium Jumbo (Carpathian Spruce/East Indian Rosewood)
2013 DIY Medium Jumbo (western red cedar/S. American Mahogany)
2013 McKnight Ukulele (redwood/mahogany)
2009 Martin D-16GT
2006 Larrivée OM-03R
Quote from: Blue in VT on April 11, 2007, 09:19:45 AM
Quote from: kwakatak on April 13, 2007, 01:57:45 PM
I agree with Blue and Kwakatak - I play on lights on my SD although I've tried mediums.  And here is my reasoning for what its worth.  When you put mediums on a guitar and perform your first open strum it almost always sounds fuller, more rounded, deeper bases etc. than when you have lights on .  However what counts is how they sound when you play ( I fingerpick btw).  If the mediums constrain your ability to express your music and make your playing sound a little stiff or leaden or , if you play blues or ragtime and find that mediums limit your ability to bend notes, then the sound of the music you actually play will sound less open ,rounded etc than when you play with lights.  It's not a macho exercise (how heavy can you go?) it's all about what works for you when you are actually playing and not just performing a few open strums.
Apologies for the rant hope I didn't ofend anyone.
Andy Perkins banjo
Epiphone Bluesmaster Sb
Gold Tone PBR Deluxe
Larrivee SD-50 MT TSb
Thanks for the answers.  It looks like the lights are s"light"ly  :arrow ahead.  I seem to have misplaced the saddle so I have some more time to decide.
Chad
