Cheap discounted pickups
Started by djsonovox, April 10, 2007, 01:25:56 AM
I've been buying discounted acoustic pickups as they go on sale at a local store. One is a Baggs Double Barrel. That means, a mic on a stem with an under-saddle piezo.
I really loathe the unde-saddle sound! So I plan to splice in a quartet of K & K pads and then I'll have a system that allows me to choose mic and/or piezo! This should be a great combo. Of course, I'll have to blend it at the amp or with a pedal. Or just rig a special cable to mix both outputs, 50-50. Or use both my acoustic amps to get a panoramic spread!
Now the question is, has anyone else on the forum installed a Baggs, and thrown away the undersaddles?
I really want the mic to capture the real ambiance of my Seagull Cedar top, but have the piezo's for times when feedback rears it's distorted head.
oh yeah--I'll send you the under-saddle strip if you want one...
Doug Jones
Larrivee (1996) LC-09
Martin (2007) D-28
Aria AD-80
Seagull S6/Cedar
Epiphone Masterbuilt 500N
Yamaha FG-512 12-string
Eko Ranger XII 12-string, EMG undersaddle p/u
Tacoma Thunderchief bass
Vantage VS-695B Electric Bass
Rickenbacker (1986) 330-12 Mapleglo  blk h'ware
Flea Ukulele
Lanakai Bari Uke
Use a stereo jack instead of the mono output jack and then use a stereo to two mono Y cord to plug into the stereo jack. Then you can send both signals to two different amps or a stereo amp, or blend them to taste with a pedal.
Works great on stereo Rickenbackers!
Doug  :bgrin:
2016 Martin 000-28vs 12 fret
2014 Taylor 814ce
2014 Godin Multiac Classical
2012 Gibson "The Golden Age 1930's" SJ200
2012 Squier Vintage Modified 70's Jazz Bass
2010 Gretsch Electromatic G5122DC
2009 Taylor GA3-12e
2004 Fender American Deluxe Stratocaster
1981 Rickenbacker 320JG
1968 Yamaha FG150 Red La
I'm toying with the idea to put a mini thumbwheel potentionmeter glued just inside the soundhole to vary the balance of mic to piezo mini's. Although, as you say, stereo is a nice option. And I do have two acoustic amps...so maybe!!
DJ
Martin (2007) D-28
Aria AD-80
Seagull S6/Cedar
Flea Ukulele
Lanakai Bari Uke
Quote from: djsonovox on May 05, 2007, 02:19:40 PM
DJ
That mic requires 6v to 15v bias power (unbalanced phantom).  Make sure your modifications/design changes take that into account.
It came with its own 9v battery clip and preamp, so it should be all right. Anything to get away from the undersaddle sound.
Sorry, been to busy to do installs and report back on sound quality. Will do so soon.
DJ
Martin (2007) D-28
Aria AD-80
Seagull S6/Cedar
Flea Ukulele
Lanakai Bari Uke
