string choice
Started by guitarforlife, July 22, 2006, 04:57:55 PM
i've used medium strings since as far back as i can remember. mostly had dreds, martind-35, taylor710, martin d-18,seagull something or other. i just bought a 72 yamaha fg-180 and it came with lights on it that look like they've been on it for a while. it sounded really good regardless. i put a new set of mediums on and i didn't like the the sound and playability as much. for some reason the strings seemed really stiff and i felt like i was working instead of playing. never had that feeling with the other guitars. this yamaha is a dred size but is a lighter guitar ,appearing not as sturdy as the others. does anyone have any experience with this particular model guitar and this situation, or any other guitar for that matter?
Have you tried John Pearse's, Slack Key strings. They are a mix of mediums and lights, I use them on my 000 with very good results. NOt too expensive at $6.50 or so a pack.
Andy
Larrivee OM9
Larrivee PO-09 Koa
Breedlove SN20
Webber 000 Cedar/Maple
Here a two good sets to consider, both have great sound and are comfortable on the fingers. They sound good for a long time, too.
Martin Fingerstyle SP mediums.
GHS Laurence Juber True Mediums, a mix of light and medium probably similar to the John Pearse set mentioned in the previous post.
I've always liked JP strings.  But the other side of the coin is that some guitars just don't take well to meds and sound better with lights.
E. Shoaf
If it felt that stiff compared to other guitars you have with lights, maybe the top bowed out a bit from the added tension, which the guitar obviously doesn't like.  Some guitars just won't work right with anything but lights.
It may also be a poorly fitted saddle from a slightly wide slot.  If there's any appreciable lean heavier strings will over torque the top and cause action and tone and volume problems.  If so, a well fitted bone saddle would make it rock.
Also try a hybrid gauge set.  Rather than a slack key set I'd try GHS True Mediums or Pearse New Mediums.  They're medium on both E's and the B, lights elsewhere.  They're actually closer to lights than mediums in tension but it's usually the low E and B that causes problems with hard playing with a light set.
