Newbie question.....advice needed,please help!!
Started by KEVING1978, June 19, 2006, 01:11:51 PM
I am relatively new to the details of guitar and guitar adjustment. I bought a D-03 about a month ago, and I want to try medium gauge strings. I have read numerous posts about the sound and tone that they bring out in the D-03,and am curious to give them a whirl, but I have a concern. I know nothing about adjusting the truss rod, or the difference in tension that this change might create. There is not a luthier close to me to adjust my guitar. So my question is can I change the gauge of strings on my dread without harming the guitar, or is best just to stay with light gauge strings? I apologize for the obvious lack of knowledge in this area, but any suggestions you could offer would be greatly appreciated.
I've rarely had to adjust the truss rod.  I change string gauges fairly regularly and haven't had any problems with any guitars I"ve had.  I've only adjusted the truss rod when I get bad buzzing on one of the strings.  I'd go with the mediums without any worry.
Larrivee D-60
Alvarez Yairi CY-116
Apollo '60's strat copy
Oscar Schimdt Uke
Have bounced between Light & Medium on my L-09s.  Only time it was a problem was when I went from Medium to Light and the guitar was set for low action w/ the mediums.  Going the other way might raise the action a tad, but nothing worth fretting  -_- over.
Cheers,
- Richard
oldWithoutMoney.com
Larrivee L-09 (w/ non-cutout iMix)
Larrivee 00-19
Larrivee OM-0312R
plus a few other treasures
If you want to learn more about your guitar, and how to take care of it yourself (sounds like a good idea to me!), go to a web site called frets.com.  Spend some time reading and you can learn how to do a lot of things yourself.  I did.  When I started playing, I knew squat about how to adjust acoustics.  Now I am able to do most work myself.  I agree with what has been posted here.  You should be fine putting the mediums on your guitar without needing any changes.  You will feel the difference between the string sets and get more volume.  Mediums can be set up for lower action as the vibration arc is not as wide as lights.
Gook luck and let us know how you, and the differences you notice, after the change.  Experiment and have fun!
