cheap rogue 12-string in need of tuner upgrade - suggestions?
Started by Caleb, June 07, 2006, 07:37:14 PM
i just acquired a rogue 12-string that is really a pretty nice guitar. looks just like a martin, all the way down to the herringbone-ish stuff going down the back. really nice finish, straight neck, and a fishman rare earth soundhole pickup installed. not bad tone, a bit thin, but i think that cause the guy put extra lights on it. extra lights on any dread is just sinful....
BUT.....
this thing wont hold tune for a second! any ideas on some affordable tuners that will help keep this thing in tune?
Check the nut slot.Do the tuners have tenson screw's on them,if so tighten them.Make sure ther's not to much string on the post.
Quote from: unclrob on June 07, 2006, 10:30:42 PM
hmm... what do you mean "check" the nut slot? do i need to put some pencil lead or some other form of lube.....is that what you mean? i'm not sure about tension screws. i do know that they appear to be complete crap....one is even on crooked. just really flimsy, thin aluminum junk. looks like they were slapped on right before lunch break at the samick factory. i'm not sure if there's any hope for them
What I meant was do the strings fit nice with no binding,or is there a pinging sound when tuning up,are the slots cut deep enough.The tuners more then likely are the problem.
Quote from: unclrob on June 07, 2006, 11:16:44 PM
slots appear to be ok. i really think its the tuners. this guitar new was $129, so whats the be expected? it really has a nice "shimmery" sound to it though. just wont hold tune long enough to really give it a workout. i have the old ping tuners off my larrivee dread that i guess i could use, but then i'll need 6 more. would these be ok to use? i might have to drill some new holes, but that's not a problem.
